Another Door seal/trim question
Postby CARS » Mon Mar 05, 2012 11:10 pm
I am finally going to cut the doors out of my sides. I just spent the last hour reading (alot of the older pics are gone. LIke photo bucket ones) and am still confused.
My sides are 3/4". Let me get this straight.
I am to wrap the door and the opening with C channel trim, and then add T trim to the door (except for the piano hinge which I like the idea of using a inner tube for a seal).
If the T trim is flush against the doors C trim, where does the weatherstrip fit??
I think I need someone to take some closeups or a drawing. Seems like there are only a few accepted methods to do this so I really don't know why I am :?
Chris'
Autobody
Restoration
Service
CARS
Re: Another Door seal/trim question
Postby CARS » Mon Mar 05, 2012 11:21 pm
The only pic I can find right now of my profile:
The door is the blue fine line tape, not the blue tape holding the cardboard together.
Chris'
Autobody
Restoration
Service
CARS
Postby Pizzaguy » Tue Mar 06, 2012 1:21 am
My weather stripping for the doors are on the inside. The seal is made with 2 layers of 1/4" ply. The outer layer is cut to exactly fit the door opening. The inner layer is cut about 3/4" smaller all around the opening. The seal fits in that slot and compresses down to 1/4". My door and jams are coated with graphite mixed epoxy to make it water proof. Details are in Steve Fredericks shop manual.
Pizzaguy
Postby CARS » Tue Mar 06, 2012 8:13 am
I see that you just added a jamb or trim. That makes sense, but what is the 3/4" C trim for? It wouldn't work in your case.
Is that only for when you skin the tear with aluminum? I am thinking that I am misunderstanding it's purpose.
Chris'
Autobody
Restoration
Service
CARS
Postby tamnalan » Tue Mar 06, 2012 10:52 pm
I used 3/4" walls too. Here's how I did it -- I borrowed the double-seal idea from the Silver Beetle build. I didn't use c channel, but instead some angle aluminum and a piece of leftover 0.04" sheet to line the door opening. Some T moulding creates the outer door seal surface. I added 3/4" of poplar framing around the door opening and to the door itself to help keep things true. I added about 1/4" of shims under the hinges to create an offset "crush space" for the two seals. I haven't used the trailer in the rain yet but the door seals passed the water hose test.
tamnalan
