Looking for Cabin Pad / Mattress
Postby Livewire » Sun Mar 11, 2012 7:11 pm
Hello All,
I am in the beginning stages of my first Teardrop build, I am wondering what everyone is using for the cabin area padding / mattress...
have you bought something to fit or is it custom made ????
Livewire
Images: 6
Re: Looking for Cabin Pad / Mattress
Postby GuitarPhotog » Sun Mar 11, 2012 7:54 pm
I had the local foam shop custom cut my 5" thick foam mattress to size. It wasn't cheap, but was a better solution for my odd-sized cabin than trying to make an off-the-shelf mattress work or using an air bed that often went flat :(
<Chas>
GuitarPhotog
Images: 55
Postby Shadow Catcher » Sun Mar 11, 2012 8:02 pm
We got our foam mattress from http://www.mattressbymail.com
Good quality, not expensive!
Postby Oldragbaggers » Sun Mar 11, 2012 8:12 pm
I also get my foam custom cut locally. I will have it cut in 2 - 3 pieces so I can stack them and clear room on the floor for bags and gear, and also to make for easy removal through the door so I can store them inside in the winter.
Life is sooooo good.........
Sail...camp....bike...repeat
Becky
Oldragbaggers
Images: 331
Postby mechmagcn » Sun Mar 11, 2012 9:07 pm
I'm using a 5'' foam topper from JCPenney. It is a truly firm foam and can be very hard when cold.
http://www.jcpenney.com/jcp/X6.aspx?Grp ... rchresults
Jeff & Micki
53 F100
Mercedes turbo diesel
Teardrop "finished" as if they ever are
You can never be lost if you don't care where you are going!
mechmagcn
Images: 56
Postby David S » Sun Mar 11, 2012 9:59 pm
I bought my memoryfoam mattress from Walmart.com
David S
Images: 53
Postby CliffinGA » Sun Mar 11, 2012 10:04 pm
Barely used Futon mattress I picked up from a friend, heavier than foam buteer greatto sleep on.
Cliff :thumbsup:
My Build:
viewtopic.php?f=50&t=42628
CliffinGA
Images: 207
Postby nevadatear » Mon Mar 12, 2012 7:43 am
I also got a memory foam topped latex mattress at walmart.com. Decent price and very comfortable. I think min is either 5 or 6 inches. I think 6. You may want to do on search on this topic, as it has come up many times before and had some good ideas in those threads.
nevadatear
Images: 171
Postby stumphugger » Mon Mar 12, 2012 11:02 am
mechmagcn wrote:I'm using a 5'' foam topper from JCPenney. It is a truly firm foam and can be very hard when cold.
A 12 volt mattress pad heater turned on 30 minutes before retiring takes care of the hardness. :thumbsup:
stumphugger
Images: 76
Postby Livewire » Mon Mar 12, 2012 4:42 pm
Thanks everyone for your great suggestions, I will look into all of them and look forward to hearing others...
Mike
Livewire
Images: 6
Postby stugpanzer » Tue Mar 13, 2012 9:46 am
Excellent suggestions!
stugpanzer
Postby mechmagcn » Tue Mar 13, 2012 9:56 am
Yeah... I've had a 120V mattress pad heater in there for 3 years, but that is no help when I camp without hookups, which is quite often :oops:
Jeff & Micki
53 F100
mechmagcn
Images: 56
Postby deceiver » Tue Mar 13, 2012 5:58 pm
ditto on the spa mattresses at Walmart. Ours is 8", 3" of memory foam and the rest hard foam. It's great. Actually going to get one for the house when our current mattress dies.
Only by online special order for store delivery btw.
Conform and be dull.
deceiver
Images: 67
Postby campmaster-k » Wed Mar 14, 2012 1:32 pm
Shadow Catcher wrote:We got our foam mattress from http://www.mattressbymail.com
What density of foam did you get and how do you like it?
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
Postby Martiangod » Wed Mar 14, 2012 10:06 pm
Just picked up a futon today, the end is gettin close,
Had futons before, so should be A-OK
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
