campmasterk wrote:Thanks Danny that is exactly what I needed to see.
The compression spring is a great Idea thanks.
nevadatear wrote:I did curtins. I used a simple dowel. I found the birdhouse ornaments on a fluke at a craft store I drilled a hole in he sides and stuck in the dowel . One side is glued and he other side not so that I can remove the curtains. I mounted them with a metal interlocking finger thing I found in the mark down barrel at the hardware store that was perfect. it fits almost flat to the wall and to the back of the bird houses. It interlocks like the old "here is the house here is the steeple, open the doors and heres all the people". Actually it is more like how you twist your hand together to be able to wiggle your middle finger on either side. If you don't remember that, then I am too old. Too bad I don't have a picture.
Users browsing this forum: Bing [Bot] and 14 guests
