NathanL wrote:I've found that small foam rollers work pretty good for coating the wood with epoxy. Can move it around and keep from putting on too much.
Oldragbaggers wrote:Good morning Tom! Nice to see you on this thread!!
Amine blush, if you have it, washes off easily enough with plain soap and water. If your epoxy has fully cured (over 24 hours) then you will need to give it a light sanding. Your next coat will be forming a physical bond and will need a bit of a rough surface to "bite" into. If it has been less than 24 hours (even that is pushing it, less than 12 is better) and your layup has not fully cured, you can layup over it without sanding and the 2 layers will form a chemical bond.
I just received my first shipment of Raka blush free epoxy yesterday and am really anxious to see how it works. I have always used either West System or Epiglass in the past and both blushed. Others who use the blush free epoxies seem to swear by them though. I will certainly post my experience here after I have used it, hopefully this weekend if it doesn't rain.
SteveW wrote:I don't think I'll be glassing my first TD, mainly because I have no experience with it and we'd like to have it campable sooner than later. However, I really like the idea and would love to do one in the future. Any suggestions for learning to glass? Where to get a good basic introduction, what's a good starter project, etc?
aggie79 wrote:In a continuation of this thread, how does everyone measure your epoxy components prior to mixing? Do you use the graduated mixing cups or pumps?
