Clever Mods
Re: Clever Mods
Postby campmaster-k » Fri Mar 23, 2012 8:46 am
Gus I too can see your pics now, I could not before. Good work.
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
Re: Clever Mods
Postby Mukilteo » Fri Mar 23, 2012 3:33 pm
:applause:
Me too.
Eric
Mukilteo
Images: 18
Re: Clever Mods
Postby Mukilteo » Fri Mar 23, 2012 3:36 pm
In fact, I went and made sure mine was checked for "Everyone"
Eric
Mukilteo
Images: 18
Re: Clever Mods
Postby eamarquardt » Fri Mar 23, 2012 3:53 pm
OK, now that I'm "qualified" to include pictures that others can actually see, I forgot to mention that the bumper pulls out 30"and I can carry a light motorcycle on it. Here is a pic of the assembly before I welded it into the frame:
26284
Cheers,
Gus
eamarquardt
Images: 150
Re: Clever Mods
Postby Wolffarmer » Fri Mar 23, 2012 10:27 pm
Good idea gus
Randy
Wolffarmer
Images: 309
Re: Clever Mods
Postby bobhenry » Mon Mar 26, 2012 2:22 pm
slowcowboy wrote:bobhenry. how do you keep the curtain store away bar or the curtain pvc pipe from sliding out going down the road or highway.
slow.
If you look real close Slow you will see it rests on the porch light ( a happy accident not good planning).
If you look even closer you will see a little black elastic bolo tie holding it in place while on the road.
Re: Clever Mods
Postby happy phantom » Sun Apr 29, 2012 8:22 am
Bob, I love that idea! 2 questions...how do you keep water from leaking between the pipes and sleeves, for instance if you are traveling in a torrential rainstorm? And also, on the inside, do you have flanges or something on the ends of the pipes to keep them from pulling all the way out accidentally?
happy phantom
Re: Clever Mods
Postby Vedette » Fri Jun 15, 2012 11:35 pm
I have done a similar sliding tube thing on the bottom of my teardrop to attach the ezee-up to if we are forced to camp on a hard surface, so it won't blow away???
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Re: Clever Mods
Postby Wolffarmer » Fri Jul 06, 2012 7:48 pm
Here is my little cleaver mod I thought up on a trip in May this year.
First there is the hatch latch. Nothing wrong with it but it is where it begins.
Now for what I call. "My squigles" Made of copper coated gas welding rod. No idea what diameter, it is what I usually have around. Use what ever is handy, can be bent and still take what happens in the end.
Open hatch and hook squigles in the latches, both sides if you wish.
And here is the whole point of the squigles.
Haven't really used it yet camping but I think it will be handy and weight almost nothing and little packing space.
Randy
Wolffarmer
Images: 309
Re: Clever Mods
Postby planovet » Sat Jul 07, 2012 9:14 am
ImageMark (& Cindi)
planovet
The Cat Man
Re: Clever Mods
Postby doris s. » Sat Jul 07, 2012 10:15 pm
Folks have made nice comments about our portable gas grill that hangs on a rail on the side of our teardrop.
Doris
doris s.
Images: 32
Re: Clever Mods
Postby doris s. » Sat Jul 07, 2012 10:29 pm
Another design feature we devised was the use of fabric in the kitchen instead of cabinet doors. I made the door covers and attached them to the outside of the cabinet with turn buttons. We turn the buttons and flip up the fabric to get to all our kitchenware. In small teardrops the cabinet doors can not be opened with stuff on the counters. This is a good solution to the problem. This also make a teardrop's weigh less.
Doris
doris s.
Images: 32
Re: Clever Mods
Postby working on it » Tue Jul 10, 2012 9:36 pm
  • I've got two new mods (is it really a mod when the initial build is still underway?) just added. The first was a sliding swivel mount for my generator (eventually to power lights/ac/and recharge batteries). Locks in place both stored and in operating position(s). I also have a lightweight brace to mount under it to further dampen vibrations (already rubber mounted).
    generator-first install, modified.jpg (112.25 KiB) Viewed 562 times
    photo added 7-2-17
  • The second mod was a set of frame mounted stabilizers, made from pipe clamps and 3/4" pipe components. Locks in raised position for travel, then simply drops down to whatever depth needed to stabilize the rear of trailer from tipping or rocking. Clever or not?, I can't say, but done for cheap in the industrial/automotive/what-have-you motif of my build.
  • 95051
  • Note: just noticed a month after building pipe clamp stabilizers (haven't been near it for that long)...the pipe clamps are mounted upside down in this picture; they lock in the up position, not down...oops...rectified that and tested, they will sustain 1200 lbs weight now.
Last edited by working on it on Mon Jul 03, 2017 7:55 am, edited 3 times in total.
173193172890148599
working on it
Images: 457
Re: Clever Mods
Postby bdosborn » Tue Jul 10, 2012 10:39 pm
How about a window insert for AC without cutting any holes in the tear:
Or a tongue mounted grill:
Side mounted table that also serves as a dinette:
Custom shelves for the stove, lantern and propane:
Images: 806
Re: Clever Mods
Postby BillZ » Wed Jul 11, 2012 6:42 am
Bruce, love the propane shelves!
I might steal that idea. :twisted:
We have been happy so far with my under-head storage mod. My wife and I can fit at least 5 days of summer clothes in it.
BillZ
