I got the seams in the panels sanded and taped and I got the formers done for the framework that will hold the sheets in position while I glass them.
Each of the three frames is 5' X 5' and will be standing up, screwed through the deck into the stringers in the box floor. They will be spaced four feet apart starting at the back so they'll support the back 8' of foam panels that make up the boxy part of the body. From there forward it's 2' for the door and then it runs forward into the nose cone so I'll have to come up with a separate bit of frame for that. This one will allow me to attach standoffs that will screw to the edges of the frame wherever I need them and attach pads that will hold the foam - as long as I remember to make sure that all the screws are accessible since I'll have to crawl inside the box to remove them and the frames. The front will still be open then so I can pull the frames out complete to use them as cold frames next spring (always thinkin'...)
Hopefully I'll get them up tomorrow or Friday because I want to start putting walls up this weekend. I'm going to miss not having a flatdeck trailer - it's come in handy a few times.
