doug hodder wrote:Semi trailer repair shops will have it on a coil. Usually in either white or in the mill finish, .040 I think. I got 103" wide and it was I'm thinking like 13$ a running foot, but that was several years ago. Check the local yellow pages for those types of shops. It's easy to cut...just lay down a sheet of styro with the aluminum on top with a blanket and a piece of ply so you don't dent or scuff it, and run a circular saw across it with a carbide blade. Just what I've done. Doug
I would love ONE continuous sheet top to bottom, front to back...
FYI if anyone is looking in the Dallas area:
DSC Truck Services 5115 S. Cockrell Hill Rd (214) 330-4661
Aluminum roofing (not the sidewall)
.050 thick
103” Wide
As long as you like!
$18.24 liner foot
