I've used both a jigsaw (with metal cutting blade) and aviation shears with great success on .040 aluminum.
The jigsaw worked especially well when I needed to cut a few pieces of 1/8in and 3/16in aluminum bar.
Javanino wrote:I'm thinking of giving that VHB tape a try on a couple of seams. Can anyone recommend a good place to purchase? Also, is there a difference between UHB and VHB? The same way there's a difference between VHF and UHF
Application Guidelines Depending on the substrates to be bonded, one of four possible surface preparation
techniques will be required:
1) Good cleaning with a 50:50 mixture of isopropyl alcohol* and water to
remove contaminants; or
2) Fine abrading of surface followed by good cleaning with a 50:50 mixture
of isopropyl alcohol and water; or
3) Good cleaning with a 50:50 mixture of isopropyl alcohol and water
followed by application of an adhesion promoter; or
4) Fine abrading of surface followed by good cleaning with a 50:50 mixture
of isopropyl alcohol and water followed by application of an adhesion
promoter.
Ideal tape application is accomplished when temperature is between 70° and 100°F
(21° and 38°C) and the bond is allowed to dwell 72 hours. Tape application to
surfaces at temperatures below 60°F (15°C) is generally not recommended.
However, on some surfaces with some surface preparations, applications at
temperatures lower than 60°F (15°C) may be acceptable. Once properly applied,
low temperature holding is generally satisfactory.
Bond strength is dependent upon the amount of adhesive-to-surface contact
developed. Firm application pressure develops better adhesive contact and helps
improves bond strength. The tape should experience at least 15 psi (100 kPa)
pressure or 15 pounds (3.4 N) downward force with a heavy duty roller.
Further surface preparation and application bonding information, including
guidelines for bonding at temperatures below 60°F (15°C), is available in the
following 3M Technical Bulletins or visit: http://www.3M.com/vhb:
Panel Bonding Procedure using 3M™ VHB™ Tape
Surface Preparation for 3M™ VHB™ Tape Applications]
Javanino wrote:linuxmanxxx wrote:If you are near austin you need to brush up on your google and phone book skillstry westbrook metals and if you want colored aluminum contact the trailer manufacturer in waco and you can get it any length and 49" wide with a wide assortment of colors and I got it for around 9 a running foot when I bought some last year. They are Continental Cargo and look for the contact information for waco and give them a call if that width works for you.
Ahh.....there lies the problem young Skywalker. Tons of places have 49". I want seamless from the front to the back so I need long unlimited coils. Worth the drive or whatever. I think I may have found a place that sells 103" wide as long as you want in San Antonio but I won't know for sure until Monday.
To be continued......
camptyler wrote:Do I need to buy one of those crazy Cyclo Polisher's and Nuvite to get the really nice "mirror" finish? Also, other than "alclad" aluminum does anyone have any alloy advice?
Thanks a ton,
Tyler
Javanino wrote:What about scratches on your aluminum. Any of you know of ways to buff out the scratches once you get them? It's inevitable that you're going to acquire scratches over time.
Users browsing this forum: Google [Bot] and 0 guests
