oil lamps
oil lamps
Postby campmaster-k » Fri Apr 13, 2012 3:53 pm
Ok ok , no hissing and boo ing. I am just sayin that oil lamps have a place . I have a couple but they are low quality and leak and are greasy and a mess. Are there oil lamp that are good and dont ooze oil all over?
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
Re: oil lamps
Postby doug hodder » Fri Apr 13, 2012 6:31 pm
I've got several Aladdins and some other wick and wick/mantle types for in the house....glass bodied lamps. All of the outdoor stuff like the Dietz and the older RR lanterns that I've got usually aren't all that tight and will leak or are kind of a mess to work with. I'm talking about the straight wick types. Doug
Re: oil lamps
Postby Ratkity » Fri Apr 13, 2012 6:51 pm
I have a couple of cheap Dietz lanterns. One sits in the house and another hangs from my redneck lantern holder on my reverse TD. It helps me find my TD, but doesn't blind my neighbors :) They are great for low light stuff, but they do leak if not kept in the upright position! I use odorless charcoal lighter fluid in them and they don't smell strong at all.
Hugs,
Ratkity
Ratkity
Re: oil lamps
Postby parnold » Fri Apr 13, 2012 8:27 pm
I've used the real cheapo ones filled with tiki oil to help keep bugs away. I recently purchased an old one to convert to LED. It should be showing up in the next couple days.
parnold
Images: 302
Re: oil lamps
Postby deceiver » Sat Apr 14, 2012 7:56 am
I've had three 'lanterns' and they all sucked. if you carry them in the trailer that bounces around all the kerosene or whatever you use ends up in the bucket I carry them in. Then I found this gem at Walmart. Here's an Amazon link to it. It's inexpensive, easy to load, produces a nice light, is well made, and doesn't leak! Also be sure to use a paraffin lamp oil. It won't smoke the glass up at all. A bit pricier but worth it and it doesn't stink. Google 'metropolitan hurricane lamp'.
This bugger is only $18
http://www.amazon.com/Lamplight-52598-Metropolitan-Oil-Lamp/dp/B000VBKE90
Conform and be dull.
deceiver
Images: 67
Re: oil lamps
Postby Ratkity » Sat Apr 14, 2012 8:01 am
Ooooo a classy oil lamp! I like it.
Hugs,
Ratkity
Ratkity
Re: oil lamps
Postby deceiver » Sat Apr 14, 2012 8:06 am
Ratkity wrote:Ooooo a classy oil lamp! I like it.
Hugs,
Ratkity
It does look nice doesn't it. It's gone about 15,000 miles now. (one 12,000 mile trip) and I've still got it and it's not broken, and it's still working well.
deceiver
Images: 67
Re: oil lamps
Postby campmaster-k » Sat Apr 14, 2012 8:17 pm
deceiver wrote:I've had three 'lanterns' and they all sucked. if you carry them in the trailer that bounces around all the kerosene or whatever you use ends up in the bucket I carry them in. Then I found this gem at Walmart. Here's an Amazon link to it. It's inexpensive, easy to load, produces a nice light, is well made, and doesn't leak! Also be sure to use a paraffin lamp oil. It won't smoke the glass up at all. A bit pricier but worth it and it doesn't stink. Google 'metropolitan hurricane lamp'.
Cool thanks, I will check it out.
-Kirk
Build thread -
campmaster-k
Re: oil lamps
Postby parnold » Sat Apr 14, 2012 8:51 pm
I got this today, but I'm going to convert it to LED with a frosted globe.
parnold
Images: 302
Re: oil lamps
Postby campmaster-k » Sat Apr 14, 2012 9:19 pm
Cool Paul great finds. Post when you get them converted.
-Kirk
Build thread -
campmaster-k
Re: oil lamps
Postby parnold » Sat Apr 14, 2012 9:23 pm
Kirk:
I should have said in the original post, that's the before and after pics. The lantern was painted ugly gold so I sandblasted it.
parnold
Images: 302
