Suggestions for finishing a lantern
Postby parnold » Sat Apr 14, 2012 7:38 pm
I picked up this neat old kerosene lantern, and I plan to convert it to LED. I'll use a smoked globe to diffuse the LED light.
As you can see from the before and after, it was painted gold, so I sandblasted it. My thoughts are either force it to rust (I found a do it yourself guide using safe household chemicals) and clearcoat it, or perhaps one of those "hammered" spray paints.
While sandblasting, I discovered that the lantern was originally red, so I guess that is a third possible option.
So help me out with suggestions please!!!
BTW, the fuel cap and the wick thingy are brass, and they cleaned up beautifully.
parnold
Images: 302
Re: Suggestions for finishing a lantern
Postby Woodbutcher » Sun Apr 15, 2012 7:37 pm
Paul, I would do it red. But that's just me.
Woodbutcher
Postby parnold » Sun Apr 15, 2012 8:45 pm
Steve:
I ended up making a homebrew rusting agent. 80% hydrogen peroxide, 20% white vinegar, and 2 teaspoons of table salt. I rubbed it on, let it dry, rubbed off the loose "rust" and clearcoated it. This is how it came out.
Right now I have it running with a 12v led panel using 8 AA batteries. I am going to see how long it will burn on a set of batteries. I actually found a globe for it at walmart, or more specifically I found a cheap candle holder with a glass globe that happens to fit. I need to frost the globe.
parnold
Images: 302
Postby bc toys » Mon Apr 16, 2012 8:46 am
I would have gone RED if it was me really don't care for rust. Its your lantern so do what you like . Would you post pix of it after you convert it to LED with globe.
bc toys
Images: 42
Postby rmclarke » Mon Apr 16, 2012 2:07 pm
I like it, Paul.
rmclarke
Images: 231
Postby parnold » Sun Apr 29, 2012 5:54 pm
I found a globe at a garage sale that fit perfectly. I frosted it using some spray on stuff I bought at Walmart. All I have to do now it get a rotary switch, and figure out how to mount is so it will be where the wick wheel was.
parnold
Images: 302
Postby campmaster-k » Sun Apr 29, 2012 6:54 pm
The rust job looks great.
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
