Wood finishing/varnishing question
Postby TheThom » Wed Apr 18, 2012 8:26 am
Hello everyone,
I'm rebuilding an old pop-up camper. I've used ACX plywood for the floor and cut grooves into it for a mock hardwood floor look
My questions: What's the best way to finish it: I'm planning on staining it. Then I'd like to find a finish that fills in the grooves so they don't constantly fill with dirt and grime. I was thinking of CPES and varnish combo
My problem: all the floor varnishes say they are not for exterior use and all of the exterior varnishes say they are not for floor use. It's a catch-22.
Any suggestions? Should I just use a million layers of CPES to fill in the grooves? Won't that make it have a yellowish tint (I was planning on a dark stain)? Is there a recommended product out there?
As always, thanks for your expertise
TheThom
Re: Wood finishing/varnishing question
Postby 48Rob » Wed Apr 18, 2012 11:41 am
You might want to try straight varnish on a test piece before trying stain.
Stain on that type of plywood usually looks very blotchy.
If that doesn't give you the look you want, you can mix stain with the varnish for the first couple coats, then go back to clear varnish.
The look you have now, lighter wood/darker grooves is very good.
Dark areas, then light areas mixed with dark grooves may not look so good.
Were it mine, I'd use Varathane oil based clear gloss floor finish. It will, with a few coats give you a very durable floor.
It will be difficult to "fill" the joints with anything that will make the entire floor level.
Since you've broken the surface, the joints will soak up more varnish, but after 4-6 coats you'll probably be happy with the results.
It should be, at that point, very easy to clean.
I see no reason to use CPES at all.
Nice job creating the joints/look! :thumbsup:
Rob
48Rob
Postby dmckruit » Wed Apr 18, 2012 1:16 pm
I would use a polyurethane. You can get the type from Minwax that has the stain already in it. It has a nice hard finish that wont mar or scuff easily. Two or three coats should do it.
dmckruit
Images: 212
Postby IndyTom » Wed Apr 18, 2012 3:00 pm
A "spit coat" of white shellac put on first will frequently smooth out the way something like plywood takes stain.
Never trust a skinny cook
IndyTom
Images: 42
Postby Zboom » Wed Apr 18, 2012 10:43 pm
I second that the plywood would blotch especially if you go with a dark stain on the pine ply. As said earlier a spit coat of shellac may help with the blotching. If you have time YouTube Charles Neil finishing techniques, he has a plethora of information on staining.
Zboom
Images: 32
Postby TheThom » Wed Apr 18, 2012 10:44 pm
Thanks for ideas.
I really liked the golden tone the underside of the plywood took with the CPES. I suspect it would do similar things with varnish or poly-finish.
Any other specific recommendations for products that are durable enough for a floor but can handle large temperature swings as well?
TheThom
Postby Zboom » Fri Apr 20, 2012 4:34 pm
Maybe look into a product called Bona Traffic
Zboom
Images: 32
Postby TheThom » Sat Apr 21, 2012 11:03 pm
I tested the stain on a scrap piece. It was a little splotchy, but not too bad. I wouldn't want that for fine furniture, but it'll work for the camper floor. I also bought some of the Varathane Oil-Based Floor Finish. The second coat of stain is drying now. Once it's dry I'll post some pics on my build thread.
Thanks for the advice!
TheThom
Postby PcHistorian » Thu May 03, 2012 9:56 pm
I liked the "Varathane Oil-Based Floor Finish" and if you put on 4 coats you may find those "cracks" start to level. first you've got to seal the bottom it though, then start to built it up. the first coats will use more because they are soaking in. The higher you go the less you'll use. I'd just advise to do the whole floor each time though, if you try to just do the cracks it might waver along the surface above them. easier to put it on a little heavier and have it flow into the cracks and level.
oh, and ps. I love the cracks look too. I gotta try that one me-self. :-)
Elf Cottage
Build Documentary
https://sites.google.com/site/pchistorian/home/hobby/camping/elf-build
Build Forum
http://www.tnttt.com/viewtopic.php?t=48462
Build Album
http://www.tnttt.com/gallery/album.php?album_id=42
progress is progress. (don't look a gift "progress" in the mouth.)
PcHistorian
Images: 198
Postby 2bits » Wed May 09, 2012 9:37 pm
Love the mock hardwood idea, what/how did you use to cut the grooves? Very creative!~
Can you post a link to your build thread too?
Thomas
2bits
2bit Member
