Diagional interior cabinets
Postby nrody » Fri Apr 20, 2012 4:31 pm
Has anyone made / designed diagional interior cabinets? Most tears I see have cabinets across the bulkhead wall. I will have a pass through door toe the galley in my tear and was wondering if diagional cabinets would provide more storage space? :roll:
nrody
Nancy
nrody
Re: Diagional interior cabinets
Postby Woodbutcher » Fri Apr 20, 2012 5:18 pm
I have a pass through from my galley. The idea was to be able to swivel my TV/CD player from the galley into the cabin.
Here is a picture from the cabin side. The small center doors are the pass through.
Here is a picture of the galley side.....
Woodbutcher
Postby nevadatear » Fri Apr 20, 2012 6:06 pm
Hmm, not sure I understand what you mean by diagonal cabinets. :thinking:
nevadatear
Images: 171
Postby 48Rob » Fri Apr 20, 2012 6:16 pm
If you mean cabinets set at 45 degrees to the side walls, with an open space between for the pass through, its not a bad idea, but I can't recall ever seeing a teardrop set up that way.
I'm not sure they would provide more storage space, but it would allow some storage, and the pass though, while not protruding too far into the sleeping space.
Rob
48Rob
Postby S. Heisley » Fri Apr 20, 2012 7:01 pm
I was going to put small diagonal shelves in my build, in the corners above the bed. Like you, with space being limited, I wanted to know what was best. To test out what I planned to do, I used paper and made the exact size and shape that I would have if the shelf was rectangular shaped and the space I would have if the shelf was triangular shaped. I actually took the things that I wanted to store on the shelf and sat them on the paper prototypes, so I could get an even better feel for it. What I found was that I actually ended up with less storage and more wasted space on a triangular shelf because very little would fit into the narrow side corner areas. While your plan is undoubtedly different than mine, if you take some newspaper or Kraft paper and mock up your cabinet shelf surface, you'll be able to tell if what you want to do will be adequate or not. Also, keep in mind that rectangular cupboards and shelves are more straight forward (excuse the pun) to build. I look forward to seeing what you decide!
Postby nrody » Fri Apr 20, 2012 8:06 pm
Most valuable information . I will do cardboard mockups. I totally get what you said about the corners. Thanks for the feedback
nrody
Nancy
nrody
Postby doug hodder » Fri Apr 20, 2012 9:36 pm
Woodbutcher wrote:Here is a picture of the galley side.....
Woodbutcher.....I love those spice bottles....I used to have a set but with red lids on them....perfect for that vintage look! Doug
Postby pete42 » Sat Apr 21, 2012 4:16 pm
woodbutcher down here in my neck of the woods those jars are used for moonshine.
ahh that's what I've been told I don't drink shine............. :thumbsup:
well maybe a sip now and then.
pete42
Postby Woodbutcher » Sat Apr 21, 2012 7:59 pm
Doug, I had a partial set in red that needed some repainting. But when I found this set complete I picked it up. Pete,The jars in my neck of the woods hold noodles and hot chocolate. But I like your idea better!!! :lol:
Woodbutcher
Users browsing this forum: Google [Bot] and 10 guests
