Your best idea for power!
Re: Your best idea for power!
Postby LDK » Thu Apr 05, 2012 7:47 am
PaulC wrote:How come nobody has mentioned Hydrogen ;)
Cheers
Paul :thumbsup:
I got it now! :lol:
I just now discovered Mikes hydrogen thread. That threads on fire!! :lol:
LDK
Postby PaulC » Thu Apr 05, 2012 12:15 pm
Cheers
Paul :thumbsup:
I was waiting for someone to mention that. You just werent the person I expected. :R :lol:
Zach , if only you knew what I'm truly capable of :lol:
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby IndyTom » Thu Apr 05, 2012 12:36 pm
[quote="absolutsnwbrdr
I was waiting for someone to mention that. You just werent the person I expected. :R :lol:[/quote]
:lol: :lol: :lol: :laughter: :laughter: :laughter: :rofl2: :rofl2:
Never trust a skinny cook
IndyTom
Images: 42
Postby PanelDeland » Sun Apr 22, 2012 9:45 pm
The most logical thing for power I can think of is to collect the solar gain from all the roadways.Should be a fairly simple upgrade once the research funding is in place,and we build/replace a ton of it every year anyway.More modern home design would reduce energy consumption.If I were to build a dream home it would be underground with a south wall out the side of a hill.That wall would be a greenhouse.Too bad the mere mention totally scares most people because they immediately think cave and run from the idea.
"I know the voices in my head aren't real,but they have some really good Ideas!"
PanelDeland
Postby LDK » Sun Apr 22, 2012 10:10 pm
[quote="PanelDeland"] If I were to build a dream home it would be underground with a south wall out the side of a hill.That wall would be a greenhouse.
I have thought about that myself. You probably wouldn't have much use of a hvac system then and could save alot of money.
LDK
Postby jstrubberg » Mon Apr 23, 2012 7:26 am
That's exactly how my parents house is built. Add a roof overhang to cut down on summer sun inside.
The still have an HVAC system, but it runs very little. They heat 2200 square feet with a tiny little wood stove and go through about three cords of wood a heating season.
Biggest problem is controlling mositure. If you do this, make sure you go over board draining water away from teh foundation. It's very easy to end up with humidity problems in an earth contact home.
The more stuff I take along, the more time I spend taking care of my stuff!
jstrubberg
Postby Fenlason » Mon Apr 23, 2012 11:41 am
The house we built is built into the south side of a hill. We have about 2500 square feet, heated with 3/8's of a cord of wood. In Maine.
72455
glenn
Kahlil Gibran
George Bernard Shaw
Fenlason
Tour de Post Yellow Jersey
Images: 221
Postby Fenlason » Mon Apr 23, 2012 11:51 am
jstrubberg wrote:That's exactly how my parents house is built. Add a roof overhang to cut down on summer sun inside.
Even if the earth around the house is bone dry... one can have moisture problems. If the concrete walls are cool, and the out side air is warm and humid, moisture will condense like on the outside of a ice chilled drink.
Making sure the shell is well insulated can help.. having the shell of the house a little warmer [which the insulation will help with] make sure to have good air flow helps of course also.
glenn
Kahlil Gibran
George Bernard Shaw
Fenlason
Images: 221
Postby niget2002 » Sat Apr 28, 2012 11:13 am
Someone needs to find a way to harness the power of Pet Drool.
Throw a pork bone to my dog and I'd be fueled up for a month...
niget2002
Postby deceiver » Sat Apr 28, 2012 5:20 pm
Cheers
Paul :thumbsup:
I got it now! :lol:
Hydrogen is clean and efficient but it almost always needs to be made from water. The Hydrogen/Oxygen bond in water is very strong. More energy is needed to separate it than you can get out of it after.
Conform and be dull.
deceiver
Images: 67
Postby LDK » Sat Apr 28, 2012 9:34 pm
We could try to harness the power from our pets. :D
LDK
Postby happy phantom » Mon Apr 30, 2012 10:35 am
I would mandate that Berkley live for 3 years under cap and trade; let them see how it would really work. its great on paper but in real life. better yet make it the university of colorado in Boulder, it gets cold there and to save the enviorment all dorms must be set to 60 degrees and have a set limit on the amount of power they can use. they can always buy more credits if they want heat.
They tried that here at UW-Madison back I think it was in the 80s. Over winter break the governor mandated that all the dorms be set back to 50 degrees. Well, they forgot that some of these dorms are very old, have steam radiators for heat, and weren't all that well insulated. It dipped into the negative degrees over Christmas and entire 10 story buildings froze up. All the kids' rooms were flooded. Not just the floors, the upper floors would leak down into the room below. EVERYTHING was ruined and it took a crew of I don't know how many guys, working straight over the entire christmas holiday and into the following week, fixing many thousands of leaks.
They won't be doing THAT again.
happy phantom
Postby jstrubberg » Mon Apr 30, 2012 1:22 pm
LDK wrote:We could try to harness the power from our pets. :D
I know this was tongue in cheek, but you made me remember a stupid thought I had driving home from the gym one evening...
Why aren't all treadmills and such connected to a generator? We might as well get a return for all that sweating! Knock the price of the KW generated off of your gym membership!
jstrubberg
Postby Fenlason » Tue May 01, 2012 6:52 am
membership!
Most people aren't that efficient.. I doubt most could turn over the belt on a full sized treadmill. Some equipment.. does generate their own power.. the power to operate the machine. They do generally ending up some dumping some excess energy [as heat] . but again for most people.. it is not a lot.
glenn
Kahlil Gibran
George Bernard Shaw
Fenlason
Images: 221
Postby LDK » Wed May 02, 2012 7:06 pm
People could take charge of their own energy independence by installing wind or solar or a combo of both
LDK
