Teardrop trailer (YU-MU)
Re: Teardrop trailer (YU-MU)
Postby Shadow Catcher » Fri Apr 27, 2012 12:23 pm
Parnold
I think what he may be asking for is the image file to be made there but in sufficient image quality.
Looks very good!
Postby oyunageldim » Fri Apr 27, 2012 12:55 pm
Thank you Parnold
But the US-Turkey very high shipping charges :NC
oyunageldim
Postby oyunageldim » Mon Apr 30, 2012 11:45 am
Hello again, continued :beer:
I did the back cover.
To prevent corrosion of sweat into making.
Polyurethane foam shook :)
The front foot.
I did lifter.
Did not do a round of composite panel.
I've scratched the inside.
Outside the image will be much better
Composite panel.
Electrical panels did
It was cheap :D
The ceiling will pop up.
I teardrop trailers
I did not see pop-up roof.
Do Have?
Glued with polyurethane adhesive
oyunageldim
Postby KCStudly » Mon Apr 30, 2012 2:59 pm
Nice work on the tongue jack and hatch frame.
Sharon's "My Away" build has a lift up roof and there are a couple others.
Postby oyunageldim » Thu May 03, 2012 11:58 am
Thank you KCStudly
I think I'll drop a complete
I continue :)
I put instead of the breather
Removing the protective tape
oyunageldim
Postby mallymal » Thu May 03, 2012 4:32 pm
FANTASTIC build!!!! That aluminium composite looks good. Was is expensive?
mallymal
Images: 18
Postby parnold » Thu May 03, 2012 8:18 pm
bu kadar hızlı oldu! çok güzel görünüyor!
:thumbsup: :thumbsup: :applause:
Spectacular!
parnold
Images: 302
Postby oyunageldim » Fri May 04, 2012 12:12 pm
Thank you mallymal, parnold :)
Yes, a little expensive composite panel
1500*3200*4mm=100usd 100*4=400usd :thumbdown:
But there are many plus
Rot-proof, waterproof, easy-painted
I'm not a master of the tree
But I'll do a good metal
oyunageldim
Postby parnold » Fri May 04, 2012 12:22 pm
oyunageldim wrote:I'm not a master of the tree
Şimdiye kadar en iyi teklif! (Best quote ever!)
parnold
Images: 302
Postby oyunageldim » Tue May 08, 2012 1:49 pm
Hi, good work everyone :)
came to the spring.
Each party flowers, insects.
I love this season :beer:
I continue
I set fenders
My feet have a very strong balance
Corners of the trailer looked bad
But now I a very nice
Before made of aluminum corner
Then I made nickel-adhesive
oyunageldim
Postby parnold » Tue May 08, 2012 2:18 pm
İşinizin gurur olmalı! Bu yıllar için römork keyfine varacaksınız. (you should be very proud of your work! You will enjoy your trailer for many years.)
parnold
Images: 302
Postby KCStudly » Tue May 08, 2012 9:55 pm
Very nice indeed. :thumbsup: :thumbsup: :thumbsup:
Postby oyunageldim » Sun May 13, 2012 1:07 pm
@parnold
@KCStudly. Thank you very much :beer:
I continue
I continued the work that is required now some little makeup :)
In these new wheels :)
Stood in the very ordinary trailer
Sticker was even more beautiful
Mr. parnold.Thank you for your attention
I bought them from ebay england
Buddha mascots, trailer that will protect :) :) :)
And exterior lighting and parking lamps, all of them will be led
Park lamps, glued with double sided tape
Thus, watertight trailer
oyunageldim
Postby parnold » Sun May 13, 2012 1:58 pm
Beautiful!
güzel!
:applause: :applause:
parnold
Images: 302
Postby oyunageldim » Fri May 25, 2012 11:43 am
Thank you parnold :beer:
I continue
Struggled a little bit back cover
I wore lock
Fender stainless metal glued on
Electrical installation too complicated
No, not fun :?
12 and 220 volt cables
Nature 12v, 220v camping areas :D
and insulation
I had to use glass wool
There is no possibility of fire
Insulation must do better
To be healthy :)
I will opens ceiling complete
To secure the latch is closed
oyunageldim
