This weekend we finally got a "roof over our head." This was the hardest part of the build for me so far and I couldn't have accomplished this part of it without Lance's help. Getting the interior overhead into place, and trying to keep it lined up (not too sucessfully on one piece of it) and in place up over our head while trying to bend and staple....a bit of a challenge I will say. I wisely invested in a pneumatic stapler before I started the job and I am extremely happy that I did. So, after what seemed like hours of Lance and I scrambling around in there like maniacal contortionist monkeys, the headliner was up.
We have a tiny bit of variance in the width of our tear from one end to the other, it's only about 1/2" overall, but that made it a little bit harder to get it cut to fit right. I didn't want big gaps at the edges. So I got my edges okay, but ended up with a big gap across the top (Doesn't it just figure?). It will be hidden under a piece of trim if I can't fill it and fair it to my satisfaction. Routing the edges of the vent opening holding the router up over my head was definitely a different feeling!!
On to the insulation. Cutting that stuff is a horrible mess. It looked like it was snowing in my yard, pink, then white, then pink again. I prefer the rigid pink stuff made by Dow because I think it gives more support, and I started out trying to cut kerfs to go around the curves, but the mess was just too much for me, not to mention the time factor. I finally gave up and decided to use that only in the flat areas and the more flexible white Polyshield in the curved areas. With the curved areas I also used 2 pieces of 3/4" thick insulation in each space instead of 1 piece of 1-1/2" like I did for the flat areas. This made it possible to cut the piece laying next to the headliner just a tad narrower for a better fit. I will say it is much easier to fill the space completely with the Polyshield because you can cut it a little oversize and it will compress into the space leaving no gaps.
The front piece of the exterior roofing was a bugger. Just because it was the biggest piece, had to curve the most and one person had to hold the bend in it and keep it down against the spars while the other person got staples in it. If you just left it flapping in the wind your glue (I am using Loctite PL Premium adhesive) would undoubtedly start to dry out while you're getting it fastened down from one end to the other. Before putting the glue down or laying the skin on I had to figure and mark on the outside of it where all the spars were located underneath so that I would know exactly where to put my staples. I didn't do a really great job of that on the interior and missed my spars completely in a few spots. (Some of you "smarter than me, plan everything" guys are probably laughing at me right now, because I am sure there is a smarter simpler way that I just didn't see.) We went a little nuts with the staples, but It will be glassed over with 12 oz. fiberglass cloth so no one will ever know they are there.
After all the exterior skin was on did some plunge cuts into the vent opening with my circular saw, cut the opening out rough with the jig saw then cleaned up that and all the rest of my edges with the router and the flush trim bit.
I will say, if this Loctite sticks half as good to the teardrop as it is to my hands and clothes, then we're in good shape!!
If any of you are wondering if I forgot about the wiring in the ceiling, no I didn't forget. This is something we have been tossing back and forth for the longest time. (And the biggest source of stress for me in this build.) After no small amount of consideration and discussion we decided to forego the DC power. I am going to do Mike S. and Casey Dog's simple electrical wireup plan for AC and the rest will be primitive, gas stove and lanterns, battery operated lights and flashlights, solar walk lights. When we have AC available we'll use it, and when we don't we'll do things the old fashioned way. After we went over all the reasons we didn't need power I said to Lance that my only remaining concern was that it would so decrease the resale value. He said that would be the grandkids problem because he didn't ever plan on selling it. That clinched it for me.
Can't wait for next weekend, my favorite,
fiberglass work!!
