I found me a 7x10!
I found me a 7x10!
Postby Partsman » Sat Apr 28, 2012 9:02 am
After work yesterday I went to look at an "Old 12 foot motorcycle trailer".
This is what followed me home!
7x10 Cargo Star with full interior, cabinets and floor already in it.
This sucker is built too. Huge channel frame, 2 5/16 ball and brakes.
I think I can put off the build thread until winter with this one.
Window, A/C, and beds is all I "need" for now.
Partsman
Re: I found me a 7x10!
Postby b.bodemer » Sat Apr 28, 2012 9:26 am
What a great find. With only a few more things you are ready to camp!
Barb
b.bodemer
Images: 328
Postby pappaw » Sat Apr 28, 2012 4:17 pm
sweet find. :thumbsup:
all you need is a blowup (bed not doll) :o
Cheers: Jeff :beer:
Image Cheers from Granny, Pappaw, and Cocoa (the Dachshund) Image
pappaw
Images: 14
Postby SteveB » Sat Apr 28, 2012 7:51 pm
That has to be to score of the year! Nice find. Steve
SteveB
Postby Partsman » Sat Apr 28, 2012 8:58 pm
Thanks all. I was realty excited when I saw the inside.
BTW It is US Cargo. Not sure where I came up with cargo star.
Partsman
Postby Gadget Man » Sat Apr 28, 2012 9:39 pm
I like that trailer.
The inside is halfway finished already. Is there any insulation in it?
Gadget Man
My kids may be smarter than me,
But I know more.
Gadget Man
Images: 23
Postby Partsman » Sat Apr 28, 2012 9:53 pm
I am not sure about insulation. I spent all afternoon on the floor.
Spent the afternoon removing chocks and diamond plate.
Took me a while to find the right screw bit.
Partsman
Postby Partsman » Mon Apr 30, 2012 8:06 am
Picked up some white Rustolium for this. If it ever stops raining here that is.
I am having trouble with the interior lights. They worked when it was hooked to the previous owners truck.
Not so with my truck. Then I tried using some jumper wires and my boat battery. Still no luck.
Partsman
Postby Partsman » Mon May 21, 2012 3:35 pm
New pics.
Stripped down the driver side wall.
The window is in! Already cooler inside!
Insulation on that side.
Partsman
Postby Partsman » Mon May 21, 2012 3:38 pm
I also scored a queen size mattress. It is thicker than I wanted but free and it was in the spare bedroom so not worn out and smelly.
Partsman
Postby bigbendhiker » Mon May 21, 2012 4:15 pm
Awesome find. :thumbsup: Looks like a really stout trailer.
While you have the interior walls off, you can plan for any additional wiring that you may want to run.
Scott
bigbendhiker
Images: 28
Postby Partsman » Mon May 21, 2012 4:40 pm
Oops! I meant to post that on my build thread.
What is the best fix?
Partsman
Postby 8ball_99 » Tue May 22, 2012 12:47 am
The inside lights should be wired to the running lights on the trailer. Plug it into the truck and turn on your lights for the truck while the key is on. The lights inside should work. You are going to want to rewire them. Trace the wires from the lights to where they connect to the trailers wiring. They are probably just scotch locked. Remove the scotch lock and run a wire from their to your wall switch.. Then just run a power wire from your power center to the light switch. These trailers don't come with onboard batteries so the lights are always just tied into the running lights. With all the interior walls exposed it should be a very easy fix.
8ball_99
Postby bigbendhiker » Tue May 22, 2012 7:14 am
8ball_99 wrote:The inside lights should be wired to the running lights on the trailer. Plug it into the truck and turn on your lights for the truck while the key is on. The lights inside should work. You are going to want to rewire them. Trace the wires from the lights to where they connect to the trailers wiring. They are probably just scotch locked. Remove the scotch lock and run a wire from their to your wall switch.. Then just run a power wire from your power center to the light switch. These trailers don't come with onboard batteries so the lights are always just tied into the running lights. With all the interior walls exposed it should be a very easy fix.
I noticed in a previous post that you plan to install a/c. You should also plan and run the power for this now.That most likely means that you need to make plans for 110v AC. If that's the case you will also probably want additional outlets for other uses. My Dad always said, "You can never have too many outlets." Now is the time to install them. Much will depend on your intended uses for your trailer. There is great advice on electrical systems in the electrical section of this forum.
Scott
bigbendhiker
Images: 28
Postby Partsman » Tue May 22, 2012 12:02 pm
I am planning the bear minimum for power. One 110 and a couple lighter sockets. The trailer already has lights.
I guess I should do the 110 now while the wall is apart.
Partsman
