Pete, it sure solves a lot of problems , while keeping the solution Simple and “Thrifty”... Much easier to bend up a dozen PVC ribs than laminate them from wood ... Cheap ... Thinking how easy it would be to bend the square stuff ...
Then these would be drilled and bolted to the longitudinal stringers which would be in turn be glued to the Foam , all contained by the skin ... Theoretically!
I have been experimenting on these bows which allows me to not only test the material itself and how to best work with it, and get a little “light weights" exercise too (doctor recommended) .. Figured I’d do my pulling and stretching in the back yard ... might as well shoot a few arrows and have some Fun ... also solves some “Security” issues too, having a stealth weapon to deter unwanted animals (or dinner) ... These PVC bows have shown amazing flexibility and toughness, with the ability to “heal” themselves (when heated) and spring back to their original shape ... Pretty Amazing... certainly worthy of My considerations on the next Foamie build , which is already in the acquisition phase ...
This stuff is downright CHEAP...STRONG... fairly Light... A “Thrifty Alternative” to be sure ... Much experimenting yet to be done ... My immediate thoughts for trailers aside from profile Ribs are PVC doors, frames , windows, Galley hatch ribs , shelf braces ... EASY!!! Nothing to rot, repair ... PVC does not like UV exposure ,not the white plumbing pipe anyway, so you have to paint it ... No problem there... Just a different use for an accepted material used in a different way than intended...
Sorta like making airplanes out of Foam
or campers
