by norcal2 » Fri Jun 22, 2012 10:48 am
got my ceiling up, insulation completed, e track mounted for the bed, dc and ac power panel installed outlets installed and the inverter mounted. im building out the front cabinets and need to install the sink as far to the right as possible for more counter space and i can clean up without going all the way in the trailer... Im painting everything white, as the space is so small a dark color will make it seem smaller i may do the cabinets in black though as the formica is a dark color and it is a dual use trailer for toy hauling, storage and camping in. The leading edge on the countertop ill probaby do in aluminum or stainless..i havent decided as it will take a beating.. i really like the maxxair thermostat reversible ceiling fan, that thing really moves some air. I need to finish up the cabinets, crown moulding and paint...I really like the recessed led lights they are nice and bright i have 2 switched next to the front door and the other two at the rear door so i can open the rear and just use the rear two lights the same with the front... The rear lights installed over the back ramp area are to bluish..im going to swap them out for something brighter
- Attachments
- 2012-06-21_20-46-04_56.jpg (201.54 KiB) Viewed 5671 times
- 2012-06-21_19-14-46_728.jpg (216.72 KiB) Viewed 5671 times
