hello everyone
I am currently into my build and stumbled across something I should research a little more " my build is a body covering the sides of the frame , and how I am doing it is with a 2x2 wood border glued and screwed to the sides and front of the frame to attach the walls so I can hide the frame from view , I sort of mocked it up with one wall to check clearance between the tire and wall and I have 1" from tire to wall which seemed ok from the posts Ive read, but there is one thing that I noticed about the torsion swing arm , it is only 1/4" from the wall and that is getting close , question is should I increase the clearance? anyone with more experience than I your expertise is accepted here please advise!
thanks in advance joe
