two pages opened to do this next section. this is just the analysis and design prep for this part. this is for the solar hot water heating design and the heat / cool air ventilation system. This falls into the area of the spaces of the roof, between the inside of the roof board, to the inside surface of the roof beams/joists. Roughly "what can you do with a 3.5 inch deep space of the roof area of an Elf Cottage (TD/TTT), to heat water, and heat or cool the interior air." (adapt to your own design.)
the tanks for the hot water are actually to be under the trailer. I'm just planning some hoses under the roof-surface to heat the water for hot water tanks.
sequence one is to define this in pictures, figures and diagrams.
![Image](https://www.tnttt.com/gallery/image.php?album_id=42&image_id=94853)
This roof in the sun will get plenty hot, un-insulated inside the board under the shingles.
Here's the beam arrangements and the general ideas.
![Image](https://www.tnttt.com/gallery/image.php?album_id=42&image_id=94854)
![Image](https://www.tnttt.com/gallery/image.php?album_id=42&image_id=94855)
![Image](https://www.tnttt.com/gallery/image.php?album_id=42&image_id=94856)
![Image](https://www.tnttt.com/gallery/image.php?album_id=42&image_id=94857)
![Image](https://www.tnttt.com/gallery/image.php?album_id=42&image_id=94858)
![Image](https://www.tnttt.com/gallery/image.php?album_id=42&image_id=94859)
![Image](https://www.tnttt.com/gallery/image.php?album_id=42&image_id=94860)
![Image](https://www.tnttt.com/gallery/image.php?album_id=42&image_id=94861)
![Image](https://www.tnttt.com/gallery/image.php?album_id=42&image_id=94862)
![Image](https://www.tnttt.com/gallery/image.php?album_id=42&image_id=94863)
resolution
These first two are diagrammed as looking straight up. the figure 8's are to show a computer muffin cooling fan (12vdc @1/4A) and are shown surrounded by an area to restrict where the air comes from, side, or end.
![Image](https://www.tnttt.com/gallery/image.php?album_id=42&image_id=94865)
I also wanted to try at least one "alternative" diagram to see if it improved the design in any way. So I came up with the staggered fan design.
![Image](https://www.tnttt.com/gallery/image.php?album_id=42&image_id=94864)
then there is the ends. the joists from the corners are about 30 degree angles from horizontal, where as the beams from the middle areas are about 45 degree angles. the ends posed a bigger problem of the ventilation because the point was so closely interwoven with the diagonal parts of the side-ends.
![Image](https://www.tnttt.com/gallery/image.php?album_id=42&image_id=94866)
![Image](https://www.tnttt.com/gallery/image.php?album_id=42&image_id=94867)
![Image](https://www.tnttt.com/gallery/image.php?album_id=42&image_id=94868)
Then lastly a cutaway of the full system: shingle, roof-board, water hoses & air gap, 1/2 inch insulation,(so of 3.5 inches, that accounts for about 1.2 inches), gap of about 2", inner surface of fiberglass reinforced panels.
![Image](https://www.tnttt.com/gallery/image.php?album_id=42&image_id=94869)
