Bob's caboose build
Re: Bob's caboose build
Postby bonnie » Thu Jul 05, 2012 6:08 pm
[quote="bobhenry" I am ashamed I didn't get more done but its just too hot.[/quote]
Don't be. It's too hot. Dangerouly, so. I'm working for a few minutes, then cooling off for what seems like hours. My poor house AC is struggling. And I don't want to see the bill that's coming. :NC
Remember, the turtle won. :)
bonnie
Images: 107
Postby Verna » Thu Jul 05, 2012 9:15 pm
bobhenry wrote: I am ashamed I didn't get more done but its just too hot.
Hey, Bob, it's OK. I was taking 60 min breaks for every 30 min bit of work on my TD. It's sitting in the shade, but it was still over 100* inside. We humans can only stand so much extreme temps...whether it's freezing at Turkey Run in January, or sweating to the hot temps in the yard in July :lol:
Oh, and of course, we're reading about your build. I think it's great that you've come up with a solution for your living arrangements. Keep up the good work!!
Verna
Indianapolis, IN
Verna
Images: 49
Postby bobhenry » Fri Jul 06, 2012 5:52 am
Mopped on a gallon of the fence posts and foundation coating on the otherwise unprotected floor before our predicted Sunday rains. So with the black stick goo on the floor I will be forced to work outside of the caboose on a taller ladder. It will take a few days for the gunk to cure to the point I will be able to work on it again.
Installed the remaining front purlins and after an hour and a half I gave up.
Images: 2617
Postby bobhenry » Mon Jul 09, 2012 7:14 am
Well it's Monday again and despite the oppressive heat I was able to get a little bit done.
The couple hours between 7 am and 9:30 - 10:00 was able to get a dab done before the heat became unbearable.
Here are some new pics Image
I like the Kabota orange It is a red orange that is kinda cheerful and looks great with the white trim!
Talked about aligning the legs so the siding would fall correctly. Here is a cago strap pulling the header section into alignment so the second sheet would fall correctly. This shot gives a good feel about the barrelled ceiling :D
Had a bowed stud that wasn't falling at 2 foot on center so I used a bar clamp to pull it into alignment.
The wheel wells got some reinforcement and it also added a nailer for the siding. Need to black goop the whole mess yet.
Here are the front and side shots. The cupalo and rear purlins are just laying in place and have not yet been installed.
And once again the yard sale gods were smiling on me......... :lol:
Yep an LP set up zero clearance fireplace at the neighbors about a block from the house for $75.00
Images: 2617
Postby ParTaxer » Mon Jul 09, 2012 7:41 am
Looking good Bob!
I have wisdom beyond my years. In fact, I'm nearly senile.
ParTaxer
Images: 32
Postby pjo129 » Mon Jul 09, 2012 10:44 am
Bob,
That's almost Santa Fe Railroad Red. :D
BTW- checking with the Mrs, trying to see about making up to Tippecanoe for Friday and Saturday. Keep your fingers crossed. If finances permit, they still have some great spots open.
Pete Olson
Newburgh, IN
pjo129
Images: 73
Postby bobhenry » Mon Jul 09, 2012 11:14 am
We are all looking forward to meeting both of you. I will be the fool in a red barn :oops:
Images: 2617
Postby WhitneyK » Mon Jul 09, 2012 11:16 am
bobhenry wrote:Well it's Monday again and despite the opressive heat I was able to get a little bit done.
Looks like you got a lot done in a short period of time. :thumbsup: Might be amazing what you could acomplish if the weather breaks and you can actually give it a full day. Really starting to take shape.
Good deal on the heater too! Seems to be working quite well already :D
Whitney & Tracie
Crothersville, IN
We never really grow up, we only learn how to act in public.
Do not confuse what you hear with what I mean.
My build: http://www.tnttt.com/viewtopic.php?t=41955
160061-------------------------------101114
States we've drug our
li'l camper through. (44 States + Vancouver Island and over 45,000 miles so far)
WhitneyK
Images: 412
Postby bobhenry » Mon Jul 09, 2012 11:21 am
[quote="WhitneyK]
Good deal on the heater too! Seems to be working quite well already :D[/quote]
Yep went by the VFW in Crawfordsville (13 miles away) and their sign read 111 Degrees
Just imagine what it can do when I get it plumbed up to the gas.
Images: 2617
Postby S. Heisley » Mon Jul 09, 2012 9:10 pm
8) It's starting to look like a caboose!
Postby starleen2 » Mon Jul 09, 2012 9:13 pm
What is that green board you are using for the exterior??
starleen2
5th Teardrop Club
Postby bobhenry » Tue Jul 10, 2012 6:58 am
This is a fiber glass faced osb called zip panel. It is great stuff I have used it for the 4x7 and the chuckwagon. I have a few chunks of it that have been laying about in the yard for almost a year with NO degradation or swelling. It is guaranteed stable for up to 6 months uncovered on a construction site.
http://www.zipsystem.com/zip-system/wall.aspx
Images: 2617
Postby mezmo » Wed Jul 11, 2012 1:39 am
Hi Bob,
Ah, Zip Panels. I was wondering what you were going to use for wall
shear,so that answers that. Will their surface be strong enough/OK as a long
term exterior finish? [Since it is sold as sheathing and not as an exterior finish,
will exterior paint be enough for that and UV protection or do you need an
exterior siding over it?]
'Fun to watch the progress on the 'Bagoose'.
[My nickname for it, which was what a cousin used to
call cabooses when she was a toddler.]
Cheers,
Norm/mezmo
mezmo
Images: 194
Postby bobhenry » Wed Jul 11, 2012 6:54 am
The very old caboose (es) or is it caboose 'I either way they were board and batten I will install 1x2 battens at 12" on center and am praying that the equipment enamel will be enough protection for the long term.
Images: 2617
Postby Lizbeth » Thu Jul 12, 2012 6:11 pm
Bob,
Just coming on board today and read the whole thread. It's been a pleasure to see what you are doing. I love the whole tiny house movement.
Liz
Lizbeth
