bigblockbarry wrote:I took the stick approach too sort of. I bought two 1/2 inch aluminum dowels that were 3 feet long and a pack of little rubber caps. $18 at Lowe's if I remember right. Made a small mount that screwed to the countertop,drilled holes through them and bolted them together with a couple small plastic washers for friction. Cut a small piece of 2x4 ,rounded it up and drilled a hole in it to screw to the hatch.
Barry
