GPW wrote:Super coolers , that means lots of Foam ... (thicker the better ) ... so why not make the cooler part of the build , built in , and part of the structure ... You would need a little glassing to make it reliably soak-proof , and a drain ... gotta’ have that ... Like the old timers did , built in “cork” lined iceboxes ... but in foam ... 4” + thick foam should keep ice for a Long time ... and just the idea of a box/beam-like structure that thick , built in , just has to add Significant strength to any area ... strong enough skinned to make a Bench top ... Good place to keep the Beer cold too
