So, here's how I electrified my Escaped2:
After a lot of contemplation, I finally got up the courage, and drilled the 2 3/4" hole for the power inlet......I hated drilling such a large hole in the side of her:
The walls are fiberglass, 1/8" plywood, 3/4" plywood and carpeting on the inside:
I put the GFI protection inside the cabinet inside the cabin, and used stranded wire, in the form of extension cords to run the 3 outlets. (I did use spade tips on the ends of the stranded wires at the electrical outlets.)
I have 3 outlets. One on the outside of the Little Guy, next to the power inlet and TV cable inlet. One in the galley, one in the cabin--both of these have surge protection.
Now, maybe I can finally take the maiden voyage in the Escaped2
