Stupid Mouse (Update: Dead Mouse)
Re: Stupid Mouse
Postby geochris35 » Fri Aug 24, 2012 12:08 pm
I agree with the glue tap suggestion. They always seem pretty cruel to me, but they seem to work better than anything else I have tried.
geochris35
Images: 22
Re: Stupid Mouse
Postby High Desert » Fri Aug 24, 2012 2:21 pm
Had one once that kept getting the PB and not tripping the trap. Tied a raisin to the trigger with a piece of thread and covered it in PB. That got the little devil.
Shaun
High Desert
Images: 27
Re: Stupid Mouse
Postby asianflava » Fri Aug 24, 2012 4:34 pm
Cheeto & Frito can't help you?
asianflava
Re: Stupid Mouse
Postby bdosborn » Fri Aug 24, 2012 5:53 pm
Cheeto is useless but Frito is my secret weapon. She's the one that caught a Hummingbird in mid air.
Images: 806
Re: Stupid Mouse
Postby kirkman » Fri Aug 24, 2012 7:05 pm
bdosborn wrote:
kirkman wrote: That is if you have a good mouse trap not one of the 4 for a dollar traps. Most of the cheep traps are not sensitive enough for a small mouse to spring.
Well I put some cheese in the trap and the mouse ate it but the trap didn't spring. Where do you get a good trap? :x
The ones I use are called mini T-Rex. http://www.domyownpestcontrol.com/mini-trex-mouse-trap-p-1303.html
They have these at lowes I have never used these but they look very similar to the t-rex ones I use they should do the job.
http://www.lowes.com/pd_230509-30313-33505_4294834276__?productId=3026154&Ntt=mouse+traps&pl=1&currentURL=%3FNtt%3Dmouse%2Btraps&facetInfo=Traps
kirkman
Images: 55
Re: Stupid Mouse
Postby Guy » Fri Aug 24, 2012 7:27 pm
Dear Bruce,
I had a whole family (5) and finally got rid of them with Ace Hardware traps and cheese. Make sure you check your electrical wiring because they may be eating through it if it is exposed to them. They really destroyed my wiring.
Regards,
Guy
Guy
Images: 44
Re: Stupid Mouse
Postby Redgloves » Fri Aug 24, 2012 8:00 pm
This summer I have caught 8 mice in my house using "Redneck Mouse trap". 5 gallon pail, long edge of coat hanger, tin can with a strip of peanut butter, and a ramp. Fill bucket about 1/4 full with water. Easiest to explain by checking Youtube for redneck mouse traps.
No squished mice to clean up, just floating ones.
Need a few more neighborhood cats! One neighbor is having mice problems, so I am not alone.
Geocacher, healthcare provider, mom and women with not enough common sense regarding personal safety when it comes to adventure outings!
Owner:
Uff Da Inn, a 2015 Camp Inn 560
Redgloves
Images: 5
Re: Stupid Mouse
Postby bdosborn » Fri Aug 24, 2012 8:06 pm
kirkman wrote:The ones I use are called mini T-Rex. http://www.domyownpestcontrol.com/mini-trex-mouse-trap-p-1303.html
Hah, that's what I just put in the trailer. We'll see what I get. Monday the cat goes in there if nothing happens over the weekend. :twisted:
Images: 806
Re: Stupid Mouse
Postby TJinPgh » Sat Aug 25, 2012 6:13 am
Realizing, of course, that catching it is only half the task.
After that, you need to go through everything and clean up after him. And, you still need to figure out how it got in there or you're likely to have them again.
You'll need to look for holes. Where do you park it when you're not camping. In the garage? If so, it could be getting in through the pop top.
-TJ
TJinPgh
Images: 90
Re: Stupid Mouse
Postby bdosborn » Sat Aug 25, 2012 8:34 am
Got him!
Images: 806
Re: Stupid Mouse
Postby mustangcats » Sat Aug 25, 2012 9:11 am
:applause: Be sure to keep the trap set for a few days in case there are others. And if you haven't already done so, be sure to caulk and seal any openings where a mouse can get in. If the trailer is stored inside a building, put out plenty of food (D Con) for the mice!
mustangcats
Images: 18
Re: Stupid Mouse
Postby bdosborn » Sat Aug 25, 2012 9:15 am
TJinPgh wrote:If so, it could be getting in through the pop top.
Hey, I'm not that sloppy of a builder. I would think that if it keeps water out it would keep a mouse out. :lol: I did check for nesting and wire chewing and there isn't any.
Images: 806
Re: Stupid Mouse (Update: Dead Mouse)
Postby kirkman » Sat Aug 25, 2012 10:40 am
:thumbsup: :applause: :beer:
kirkman
Images: 55
Re: Stupid Mouse
Postby TJinPgh » Sat Aug 25, 2012 3:52 pm
I wasn't implying that you were sloppy. Nor was it intended as an insult. But, it obviously got in somehow.
Having raised more than my share of small rodents I can say that a mouse can fit through places you'd never imagine. It takes nothing any bigger than a whole the size of a quarter for them to squeeze through if they are motivated enough.
Given how quickly they grow, one can be a month or so old and squeeze through something as small as the slots on your fridge vent. A few weeks later it may be too big to get back out.
Hopefully, that's the only one. If it's not, though, may I make a small suggestion?
If you find more there's probably an access point that you're missing. My suggestion, as unpleasant as it may be, would be to take most of the removables out of the camper, put a couple of smoke bombs in a coffee can and close up the camper, but leave all the cabinets and such open.
One, it will let you visibly see any gaps you may not be aware of.
Two, the mouse will likely exit the same way it came in unless it isn't possible.
Shouldn't take more than a couple of hours to air it out once it's done if you can remove anything fabric covered.
-TJ
TJinPgh
Images: 90
Postby bdosborn » Sat Aug 25, 2012 4:30 pm
I think the mouse got in the trailer when I was camped at the Walk the Wind gathering. I left the back door open a lot and that's when I found the bagel with a mouse hole in it. I'll keep an eye on things but this is the first mouse in 8 years and 2 campers.
Images: 806
