Aussie Swag trailer suspension in action
Postby Ron Dickey » Sun Aug 26, 2012 11:02 pm
Aussie out back trailer often offer independent suspension like this
http://www.youtube.com/watch?v=uMbJte6wUlU
I found one forum where alinement was a problem
http://myswag.org/forum/index.php?topic=7388.0
Aussie site for swag type trailers not teardrops but they do a lot of camping where roads are very rough.
173882......173887
Ron Dickey
Images: 787
Re: Aussie Swag trailer suspension in action
Postby Dale M. » Mon Aug 27, 2012 8:33 pm
Not anything unique...Its just a triangulated arm with two pivot points for "alignment" and a air bag.... Pretty common concept on some of the newer cars for rear suspension when car uses front wheel drive... Something similar has been used on rear of VW beetle since "69" only it also incorporates a drive axle and torsion bar........
Dale
Dale M.
Images: 18
Postby Ron Dickey » Wed Aug 29, 2012 11:20 pm
Dale,
and how do you think this compares to the leaf spring system equal or less so.
here is a closer look at one like it but with more shock system.
http://www.youtube.com/watch?v=M15c_5I2TZQ
this is my favorite trailer the T-Van with different kind of galley.
with a little different suspension from the down under.
Ron
173882......173887
Ron Dickey
Images: 787
Postby Dale M. » Thu Aug 30, 2012 9:56 am
Ron Dickey wrote:Dale,
Ron
I find it funny that there is a chain for a travel limiter, if one needed a travel limiter an nylon/synthetic "strap" material would be a lot better choice... Synthetic straps have been used in off road and racing world for years for travel limiters...And the shocks are at such a low angle they are useless....
For a shock to be useful it has to be at about same angle as direction of axle travel.... For every degree a shock is off the line of travel of axle it loses something like 5-8 percent efficiency ( don't quote me on numbers because I have do do the research again to get correct percents) but by time shock is at 45 degrees to angle of travel it no longer functions....
Actually this style setup was discussed here many months ago ( maybe a year of more) in depth so If you can find the old thread there is a ton of "concept" and actual design information.... Several off road/expedition/trek "gear"trailers use this concept... Its ok, serves it purpose for rough country where ground clearance is desired and overall height is not issue, but probably less practical than a bar axle for most trailers that will not ever get off the asphalt and want the low profiles appearance aspect... This link below is not one I has in mind, bit its another "discussion"...
viewtopic.php?f=35&t=49615&p=923176&hilit=watts+link#p923176
Dale
Dale M.
Images: 18
