atahoekid wrote:To keep my doors on the Road Foamie from flying open and closed and slamming into the body and stressing the hinges, I want to anchor them with 5# sandbags. I'd tether the doors to the bag with a strap or rope and I have enough canvas to make the bags and enough sand to fill them. So here's where I need your thoughts. I can't sew the seams since our sewing machine isn't heavy duty enough especially once they're filled. I was thinking about gluing the seams. What kind of glue should I use? I doubt that TB2 or GG would hold a 5# bag closed. Maybe there's a better method I didn't think of... Thoughts?
GPW wrote: I’m still trying to figure out the sand bag proposal ...![]()
GuitarPhotog wrote:You can buy ready-made sand bags at any photo, cine, or theatrical lighting supply store. Or you can make your own such as these
http://www.johndcorson.com/blog/2010/03 ... -sandbags/
I made a couple of those and they're great. My sewing machine is the lightest duty possible, but I was able to make three of those.
<Chas>
atahoekid wrote: My rear doors are like cargo trailer doors. Because of the way I designed the trim at the bottom the doors will only open to 90 degrees to the body. If they folded flush against the body, I could use a hook and eye but I also want to be able to open those doors and hold them in whatever position I choose, depending on the campsite I find myself in. The door acts as a windbreak for the propane stove. .
M C Toyer wrote:atahoekid wrote: My rear doors are like cargo trailer doors. Because of the way I designed the trim at the bottom the doors will only open to 90 degrees to the body. If they folded flush against the body, I could use a hook and eye but I also want to be able to open those doors and hold them in whatever position I choose, depending on the campsite I find myself in. The door acts as a windbreak for the propane stove. .
This is what I used for my galley doors - they are 2 foot wide and 4 foot tall.
http://sell.lulusoso.com/selling-leads/1543904/Folding-lid-support.html
You can find heavier duty versions
http://www.thehardwarehut.com/catalog-product.php?p_ref=17981
and also ones that can lock at various angles besides 90 degrees:
http://www.vandykes.com/adjustable-trunk-stay-brass-pltd-steel/p/210302/
KCStudly wrote:Okay, for the cargo doors, if the best solution is to tether the doors to the ground, I would consider tent stakes rather than sand bags. They are lighter and easier to stow than sandbags, and, IMO, would provide a more secure anchorage, assuming most compatible soil conditions.
