I had a small trailer (48"x42" platform) for which I had no use for. At first I had planned to extend the platform, move the axle back etc. etc. to turn it into an ice fishing shack, but found out that it would be too much expensive for the metal to justify the expense.
Then one night, looking at deer blinds, in downed on me! Turn the trailer into a "balemobile" Basically, a replica of a hay bale on wheels
Construction started the next morning! It is fully insulated, floor and walls, I made the windown from scatch, they are double sealed pane of glass to avoid condensation and the door was also built from scratch. the walls are of an overall thickness of 2" while the floor is 4". No fancy construction material, just 2x4's ripped to size and and 1/4" OSB.
As for the idea stolen from the gentleman, it was the use of weed fabric (the cloth type) to cover the OSB to waterproof the construction. I found this material very easy to work with and on a test I tried out before, once the paint was dried, it was impossible to separate the cloth from the OSB whitout pulling the OSB apart.
This is not a fancy construction, I could have spent more time to make it fancy, like sanding gown the joints etc. but deer don't care for fancy!
Anyway, iy is always fun to look at pictures, I posted a few and more can be found here. http://smg.beta.photobucket.com/user/Mo ... e%20mobile
