FoamStream...
Re: FoamStream...
Postby bonnie » Sat Oct 06, 2012 5:54 am
That is very cool. :)
Remember, the turtle won. :)
bonnie
Images: 107
Re: FoamStream...
Postby eaglesdare » Sat Oct 06, 2012 5:55 am
you have no idea how jealous i am here!!!!!!!!
i have been keeping my eye out for any kind of construction going on around here. i want to approach them and ask about the foam. i hope i get lucky one of these days.
Louella
May the foam be with you.
eaglesdare
Re: FoamStream...
Postby GPW » Sat Oct 06, 2012 7:22 am
it’s the Cosmic law of numbers ... if you keep looking , it’s bound to turn up ... ;) the more times you look , the faster it happens ... numbers eh ? :beer:
Rib assembly pic ... Little grease pencil marks on the floor @ 72” keep each rib bottom the same width whilst drying , assuring perfect alignment later ... That’s Important ...!!!
Re: FoamStream...
Postby mikeschn » Sat Oct 06, 2012 7:58 am
GPW wrote: Funny , they asked if I wanted a whole pallet of foam ... Hmmm??? What could we do with a pallet of foam :thinking: :o :roll:
Make portable deer camps of course!!! :lol: :lol: :lol:
Nice looking FS ribs!
Re: FoamStream...
Postby GPW » Sat Oct 06, 2012 8:19 am
Hmmm? That’s True huh ??? :thinking: Seems there would be a demand for them , especially around this time of year ... possibly another business opportunity ??? 8) They don’t need anything fancy , just a warm box with a door and some windows and a Camo paint job ... pretty easy ... Deer Cozy ... or a Duck cozy ... :thinking: :roll:
Thanks Mike !!! How’s your Foamie coming along ??? We’re all anxious to see your new Foamie trailer!!!! ... :thumbsup:
Re: FoamStream...
Postby GPW » Sat Oct 06, 2012 8:59 am
Decided to expedite the rib assembly , gluing the outer assemblies all at once ... :thumbsup:
Re: FoamStream...
Postby wagondude » Sat Oct 06, 2012 11:27 am
Well, if you make the deer camps, your rib design could easily be modded to make foam hay bales. If they need a place for a cot, two bales together would be easy enough. We have all seen the bale trailer. nothing short of genious IMO.
Bill
101137
wagondude
Images: 35
Re: FoamStream...
Postby GPW » Sat Oct 06, 2012 12:58 pm
Wagon ... Dude ... That’s Brilliant !!! hay bale trailers ... Foamstreams with flat ends :o :thinking: :thumbsup: 8)
So Easy to do , nothing fancy ,and I can paint hay bales all day .. :thinking: For traveling , a canvas snap on Nose cover to streamline it ... :thinking:
Re: FoamStream...
Postby GPW » Sat Oct 06, 2012 4:16 pm
Ruh Roh !!! Things getting interesting now , Vincent sent me this : “ how about a set of ribs to make up a teardrop with galley in the rear, etc...and we can cast some deco looking rocket fenders,..all skinned in sheet metal for a DIY mini airstream? Now that could be fun to do. “
The game is afoot !!! :o :thinking:
Already planning a way to hot wire out a round nose section ... see pic .. Hot wiring on 3 axis ... ;)
FS nose .png (15.25 KiB) Viewed 1973 times
Re: FoamStream...
Postby KCStudly » Sat Oct 06, 2012 7:28 pm
Camo deer blinds is the perfect opportunity to try the camo deer blind mesh material as an outer skin. Use TB2 or 3, or the clear base paint.
Nice progress. No turning back now. :thumbsup:
Re: FoamStream...
Postby mezmo » Sat Oct 06, 2012 11:02 pm
Those CNC cut ribs look fantastic ! They make one want to check further into
the CAD programs. The cost to have one's design cut out may be worth it -
even if we aren't as lucky as" some" [Ha !} to have friends who are wiling to do it.
I seem to recall a good while ago that there were some posts [a thread ?]
somewhere on here on/about building your own CNC set-up. 'Need to check
into that again too ! Unless you have a good well fixtured workshop it can be
quite frustrating to get the tolerances and finish level you may want with
handyman grade hand tools. [Especially if they are wearing out like mine are !]
['Not knocking any builds accomplished with such - Bravo to all of them for
their good results !]
'Too tired to look back for any mentioned details on this aspect, but I'll throw out
a suggestion for a method of applying the foam planks: Since you're going to
hot-wire cut the foam into thinner slabs/planks you could a hot-wire or just use
a table saw to cut a sawblade thick kerf in the thin edge and use a couple inch
wide spline of some non-wood material, or even cedar, that would be used to
keep the foam slabs in alignment as you glue them up horizontally like logs,
and once you get to the roof curvature, you could bevel their edges to allow you
to match the curvature. Ignore this if you've decided on another method.
Anyway, it will be extremely interesting to watch the build as it progresses.
Foamstream Ho !
Cheers,
Norm/mezmo
mezmo
Images: 194
Re: FoamStream...
Postby mezmo » Sun Oct 07, 2012 12:15 am
Hi GPW,
I just came across something very similar:
http://makeprojects.com/Project/Build+a ... HEX8k2HKSp
Sure looks similar eh ?
Cheers,
Norm/mezmo
mezmo
Images: 194
Re: FoamStream...
Postby mikeschn » Sun Oct 07, 2012 3:30 am
Glenn,
Did you see this deer trailer, aka bale of hay?
viewtopic.php?p=964036#p964036
Re: FoamStream...
Postby mikeschn » Sun Oct 07, 2012 3:36 am
That looks like the one the Mad Housers put up...
http://www.flickr.com/photos/96512941@N ... madhousers
mezmo wrote:Hi GPW,
Cheers,
Norm/mezmo
Re: FoamStream...
Postby GPW » Sun Oct 07, 2012 5:11 am
Yes, the ribs were always the snag with this project and I was LUCKY (fortunate) to have my Friend cut them out on the CNC machine .... And as it worked out , we figured the cost of the ply + the machine time was equivalent to buying the Conestoga Ribs from a Wagon supply , and then those were too short and didn’t accommodate the stringers or the “hangers” (the holes to hang things from ) as these ribs do ... so this all worked out Great ... :thumbsup: There was the machine drawing time /effort , but since that’s saved info now , others may benefit from this without that charge ... 8)
KC, Any Camo pattern they want eh ... :thumbsup: 8)
Norm, that is a great idea for joining the foam ... Thanks !!! :thumbsup: That Make project is pretty cool huh .... Bigger one would make a great “Hanger" for the Foamstream or most any small trailer ... :thinking:
Mike , I did see that Haybale trailer ... Pretty Cool eh , but a little small for me ... but Perfect for a hunting trailer ... I’d need a “double wide” bale, just for relaxing or taking a nap if the hunting is slow .... :lol: :lol: :lol:
The gentleman I talked with yesterday (the roofer) told me his FIL owns some acreage and rents land to hunters , and liked the idea of small “ camps “ that the hunters could stay in too ... kind of like a "package deal “ ... We’ll see where this goes ... :roll:
Also the roofers got done with my repairs and left me a good deal of leftover R panel , all quite usable ... Seeing the Make project with the “tin’ covering gives me some ideas ... :thinking: 8) So many ideas ... so few helpers ... I need to hire a crew ... or do like Eagle does and have a “Gathering” ... ;)
