StyroSpray 1000
StyroSpray 1000
Postby ghcoe » Mon Oct 08, 2012 7:27 pm
This stuff looks very promising for Foamy's.
It can be used as a coating and a glue. It is a two part, but is environmentally friendly. :)
In one of the videos it specifically said it would hold fabric to foam for structural strength. :)
It is for both extruded and expanded foams. :)
It also can be applied in multiple layers to build up a nice smooth finish. :)
Watch the videos and check out the pictures. Making the balloon dog was cool and you can get a idea how strong and smooth it turns out. :twisted:
Price does not seem too bad. :NC
http://www.industrialpolymers.com/categ ... duct-list/
George.
ghcoe
Re: StyroSpray 1000
Postby atahoekid » Mon Oct 08, 2012 9:27 pm
Sounds promising. :thinking: :thinking: It will be interesting to see it tested. Any volunteers?
Mel
atahoekid
Images: 158
Re: StyroSpray 1000
Postby pete42 » Wed Oct 10, 2012 6:22 am
wow sounds great but at $120 for two gallons I wonder what a foamie would weight and how many gallons you would need.
pete
pete42
Re: StyroSpray 1000
Postby ghcoe » Wed Oct 10, 2012 5:53 pm
Still going to be more economical than aluminum, if you want a smooth finish. I would think 2 gallons would be more than enough for a standard sized TD if you just use it on the outside and use paint for the inside canvas.
I wonder after watching them make the baloon dog if you would even need canvas on the outside. If you did not have to cavas the outside it might make up for the extra cost. :roll:
George.
ghcoe
Re: StyroSpray 1000
Postby GPW » Thu Oct 11, 2012 4:53 am
GH, Foamies are not about a smooth finish .... It’s about Light , Thrifty , and Convenient .... Did you read the “Big” thread???
Re: StyroSpray 1000
Postby bonnie » Thu Oct 11, 2012 5:51 am
I saw this and though about how it could be used as a filler for the weave and extra bumps the BUB has. While it doesn't meet my thrifty level, it is a tempting thing to have the interior walls smooth. While foamies are thrifty and all, they are evolving too. This foam could be another way to protect more artful additions to the designs we are making. :)
Remember, the turtle won. :)
bonnie
Images: 107
Re: StyroSpray 1000
Postby atahoekid » Thu Oct 11, 2012 10:09 am
GPW wrote:GH, Foamies are not about a smooth finish .... It’s about Light , Thrifty , and Convenient .... Did you read the “Big” thread???
Remember, GPW, to each his own. Not everyone one, though most are worried thrifty, others have some degree of expendable resources. At $120 for the two gallons, I personally would have to think long and hard about using the material but in the long run I spent a lot more than that on fiberglass and epoxy. Also remember that some of us like a smooth finish and go out of the way (money and time wise) to get one. The lot of us are already one off from the standard teardrop build line of thinking and we got here by thinking outside of conventions, we should encourage free thinking... The thread started off being all about thrifty but that's not where it should end.
Just trying to encourage free thinking and open discourse.
Mel
atahoekid
Images: 158
Re: StyroSpray 1000
Postby GPW » Thu Oct 11, 2012 1:53 pm
OK, My Bad .... No Rules eh ??? Just lots of testing first ... :roll:
Re: StyroSpray 1000
Postby ghcoe » Thu Oct 11, 2012 7:27 pm
This video talks some on StyroSpray 1000.
http://www.youtube.com/watch?v=0BQJPhWqkpI
Also, from their site:
StyroSpray is 100% solids polyurea hard coating product; it contains no water or solvents to evaporate away. Most water and solvent base paints contain 30 to 40% water or solvent which is lost.
George.
ghcoe
Re: StyroSpray 1000
Postby atahoekid » Sun Oct 14, 2012 12:51 am
GPW wrote:OK, My Bad .... No Rules eh ??? Just lots of testing first ... :roll:
YUP and if you think of an idea and no one else can give you input, I think it becomes your responsibility to test it and share with the rest of the curious minds around here... :thumbsup: :)
Mel
atahoekid
Images: 158
Re: StyroSpray 1000
Postby GPW » Sun Oct 14, 2012 5:26 am
Agreed !!! But I still can’t think how it would hold the Cabin together as well as a fabric would ... Just the skeptic in me as we’ve used heavy coatings in the past (epoxy coatings from the oilfield ) which eventually cracked and failed ... over time ... :thinking: New product , unproven with the “test of time” , vs. a long proven ," Bona fide “ canvas covering that we Know works ... You see my dilemma.... :roll: JMHO
Re: StyroSpray 1000
Postby ghcoe » Sun Oct 14, 2012 11:22 am
I think there may be a misconception here. StyroSpray can be used with fabric/cloth for strength. They talked about it breifly on one of the videos.
Watching them build the balloon dog they used StyroSpray over a 10'x3' balloon, 3 layers, and then they deflated the balloon and cut holes into each end with a hole saw. Also they knocked on it with their knuckles and it sounded solid. If you look at the specs it shows it has a tear strength of 275lbs. per square inch. I just thought it might be something to consider, once tested of course.
http://www.youtube.com/watch?v=f5bBQY_lma0
George.
ghcoe
Re: StyroSpray 1000
Postby aggie79 » Sun Oct 14, 2012 1:00 pm
Just think of two-part truck bedliner. This is basically the same stuff.
Re: StyroSpray 1000
Postby pete42 » Sun Oct 14, 2012 4:40 pm
small Sample is on it's way now I'll see what it's about
sounds great to me either way alone or over fabric.
pete
pete42
Re: StyroSpray 1000
Postby linuxmanxxx » Mon Oct 15, 2012 8:27 am
This looks really good and they state you can cover it with oil or water based paints. Very interesting indeed good find and I'm with spray it on no canvas as the plastic is the hard adhered shell so why use anything between it and the foam?
linuxmanxxx
Images: 10
