Drawer Glides, do you use then or not?
Postby len19070 » Sat Oct 13, 2012 6:23 pm
I just finished up a real nice Teardrop for resale and in the Galley It has 3 drawers.
A guy asked why I didn't use Drawer Glides (with rollers) I told him I use a Friction glide and you have to lift the drawer first to pull it out. We had these on Ship because they wouldn't open while bouncing around....same as in a Tear.
I used drawer glides in 1 tear and it was always another thing I had to "Bungee" up before I took off. Or, another thing to forget!
If I forgot, they were always coming open, and shutting in transit.
On a shelf for a cooler where you can put a lock on it I'm OK.
But....
Do you think Drawer glides are worth it?
Happy Trails
Len
len19070
Images: 24
Re: Drawer Glides, do you use then or not?
Postby Wimperdink » Sat Oct 13, 2012 8:09 pm
I'll vote for friction guides which is what I have.
Wimperdink
Images: 33
Postby pete42 » Sat Oct 13, 2012 8:14 pm
being an old sailor I liked the lift to open drawers, once learned they are easily opened
I think the "stay closed" outweights the slide feature
one of my factory built travel trailers had "lift to open" drawers
pete
pete42
Postby GerryS » Sat Oct 13, 2012 8:29 pm
Friction guides. Simple is good.
Drawers in a home that will get a LOT more use are a different discussion,...
GerryS
Postby Woodbutcher » Sat Oct 13, 2012 8:54 pm
Hate to be different but I am a drawer slide guy, Never have needed to bungee them closed. Never had any sort of problem at all.
Woodbutcher
Postby halfdome, Danny » Sat Oct 13, 2012 9:23 pm
I use full extension, side mounted, drawer guides and have no issues since they have a detente that keeps them closed.:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby doug hodder » Sun Oct 14, 2012 7:06 am
If you use the more inexpensive slides, you can get a cheap pinch type roller latch to go on the back of them to hold them closed. I usually only put in 1 drawer, but the cooler and stove/pantry are on sliders. My drawers stay shut, but the cooler will slide without the lock on it. Doug
Postby aggie79 » Mon Oct 15, 2012 8:11 am
Woodbutcher wrote:Hate to be different but I am a drawer slide guy, Never have needed to bungee them closed. Never had any sort of problem at all.
I also like slides. I use the "RV" versions of the K&V slides that have a stronger close spring to keep the drawers from opening.
My biggest problem with my hobbies is that I don't have much time to spend on them. The slides are expensive, but it saves me fabrication time. (I also buy pre-fabricated drawer boxes for this reason too.)
Postby nevadatear » Mon Oct 15, 2012 8:16 am
doug hodder wrote:If you use the more inexpensive slides, you can get a cheap pinch type roller latch to go on the back of them to hold them closed. I usually only put in 1 drawer, but the cooler and stove/pantry are on sliders. My drawers stay shut, but the cooler will slide without the lock on it. Doug
Ok would like more info about these.
nevadatear
Images: 171
Postby len19070 » Wed Oct 17, 2012 2:11 am
Thats a pretty good idea Doug.
I forget what there called but everybody has seen them. Have to look up the name tomorrow.
Thanks.
Happy Trails
Len
len19070
Images: 24
