FoamStream...
Re: FoamStream...
Postby mezmo » Fri Oct 19, 2012 7:31 pm
Hi GPW,
Something else for "reference":
Click on "Foam Strip Plank Boatbuilding" in
the articles listed under the TOC on the upper
left side [Issue 34, Spring 2012].
http://www.epoxyworks.com/
Wouldn't "cove-and-bead-ing" eliminate all that
kerf-work ? it could be done w/ hot-wire cutters
set up in jigs, it wouldn't need much/any "chinking"
with spray-foam, just the gluing them together should
bond and seal the "cove & beaded" joints. It would also
eliminate most of any "foam-dust" generated if saws
are used to kerf-cut.
Just another approach.
Cheers,
Norm/mezmo
mezmo
Images: 194
Re: FoamStream...
Postby Wobbly Wheels » Fri Oct 19, 2012 8:33 pm
Dunno about styrofoam but I worked on a boat that we cored in 1 1/2" structural PVC foam. The edges had coves and beads cut on a router table once the foam 'planks' were spiled (tapered). It worked great, the trick being to match the adhesive to the foam in terms of hardness to eliminate hard glue lines in the faired finish.
Wobbly Wheels
Re: FoamStream...
Postby GPW » Sat Oct 20, 2012 4:59 am
Many ways to skin that Cat ... er, trailer ... All what’s best for You .... ;)
Re: FoamStream...
Postby GPW » Sat Oct 20, 2012 7:28 am
A while back , somebody posted a picture of a “Jules Verne” , inverted boat-like trailer , done with strips ... Probably the original inspiration for the FoamStream (haven’t been able to find it since) ... For my particular situation , that could easily be done with strips of foam , narrow strips along the curved areas ... filled in with spray foam , then sanded to shape and covered... Still seems like a Lot of work ... :o
Since only half the distance of the sheet foam height on the FS has to be kerfed’, that and the kerfs are 10’ long , the simple hot wire ‘kerf plane” will be quick and efficient ... for me ... Not too messy just leaving long V shaped strips of foam to recycle or move to the skip... And the kerfed foam will be Smoothly rounded on the exterior... no extra sanding (shaping) before putting the canvas on :roll:
... another consideration that’s come to mind lately is some extra reinforcement of the roof ... Why ? Just “because “ ... (It’s complicated ! ) The thought was to add an extra layer of TOUGH reinforcing material over the top third of the cylinder (roof) Could be a polyester mat , fiberglass glued with the chosen covering adhesive , kevlar , carbon fiber mat .... many choices , but the idea is just to add a bit of extra strength (puncture resistance ) to the top... Foam is easy enough to patch , but the smaller the damage , the easier the patching .... Just trying to consider “possibilities” ... Wouldn’t increase the weight much , but would increase the “confidence” , especially here, out in the woods with many trees that seem constantly to shed limbs ... :frightened:
Re: FoamStream...
Postby droid_ca » Sat Oct 20, 2012 11:27 am
GPW wrote:A while back , somebody posted a picture of a “Jules Verne” , inverted boat-like trailer , done with strips ... Probably the original inspiration
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Re: FoamStream...
Postby GPW » Sat Oct 20, 2012 11:38 am
Droid , that’s the One !!!! :thumbsup: 8) 8) 8) THANKS !!!!
Re: FoamStream...
Postby droid_ca » Sat Oct 20, 2012 11:51 am
no worries I like it too looks like an elephant to me just needs some ears
“Fide Canem”
droid_ca
Images: 176
Re: FoamStream...
Postby GPW » Sat Oct 20, 2012 12:50 pm
That nose is pretty strange eh ? but I'’ll bet it slices through the air pretty well ... :D The rear part is similar to the FS ... sorta’ :thinking:
Re: FoamStream...
Postby droid_ca » Sat Oct 20, 2012 1:29 pm
I thought of something similar for the front of a vardo style trailer or if its a tiny house make it five walls instead of four
“Fide Canem”
droid_ca
Images: 176
Re: FoamStream...
Postby loaderman » Sat Oct 20, 2012 1:38 pm
The angled nose gives more room on the trailer as you use the A part at he front.
However for wind resistance it really does not help, curves are better.
loaderman
Re: FoamStream...
Postby GPW » Mon Oct 22, 2012 6:33 am
The FoamStream solves both of those problems ... Rounded Nose (slippery) , which uses the front A on the trailer ... more space , 14.13 sq.ft. to be exact ... That’s a Lot of extra floor space really ... :thinking:
Re: FoamStream...
Postby GPW » Wed Oct 24, 2012 9:57 am
Funny thing about those ribs hanging around ... Everybody wants to walk under them , like it’s some kinda’ HS ring ceremony ... :R Showed the band last night ... their response was .. “ guess we’ll have to help you carry it outside and put it on the trailer Again ! “ :roll:
Re: FoamStream...
Postby GPW » Sun Oct 28, 2012 9:01 am
FoamStream moving along Slowly ... next on the list is the final Lumber purchase of the stringers and the flooring materials (cedar fence boards) .. Then there’s the two new rims and tires , one of the old nasty ones cleaned up and used for a spare.
Got the area measured out in the Studio for the skeleton build , going to mark all the measurements with chalk and lines on the concrete floor , just so we get an exact alignment.. have to also make two fixtures for Plumb ribs on the ends ... since all the stringers will be marked at one time , all should fit identically and exactly with no “adjustments “ ... The skeleton is the framework that we’ll hang everything else on , so if we get it Right, foaming and covering will be Easy ;) ... There IS enough room to get the skeleton out of the studio garage door .. so it’s all good so far , just Slowly progressing ... never fast enough to suit me ... just so many other daily things competing for our Time ... :duh:
Re: FoamStream...
Postby atahoekid » Sun Oct 28, 2012 4:40 pm
I figured out while building that there's no such thing as enough time and everything takes longer than you want or thought it would Made me crazy!!! Just part of the game. Wish I figured that out at the time. Would have lowered my blood pressure. LOL ;)
Mel
atahoekid
Images: 158
Re: FoamStream...
Postby GPW » Sun Oct 28, 2012 5:00 pm
Mel, only good thing is a long deadline ... Got till June 1 2013 to finish it completely , ready to go ... really like to have it done much sooner ... ;)
Yours took a while , but look how NICE it came out !!! :thumbsup: :applause: 8) 8) 8)
