TopWell Im finally putting the top on my
Postby Boanerges4 » Sat Oct 20, 2012 9:45 pm
:thinking: :thinking: Well Im finally putting the top on my 6x11 standy. My question is that I would like to put some type of bonding agent between the luan on top and the 29 gauge metal that I will be applying. Im sure someone can help me with this matter. Thanks so much.
Boanerges4
Re: TopWell Im finally putting the top on my
Postby Miriam C. » Sun Oct 21, 2012 8:46 pm
:thinking: Most people float the aluminum so it can swell or shrink with the temps. Don't know what to use to glue it down. :(
Postby Lgboro » Sun Oct 21, 2012 10:54 pm
3M makes a glue that works well but is expensive. I like many others floated my aluminum. The vents, windows and doors along with the trim will hold your siding in place.
Lgboro
Images: 53
Postby Gage » Sun Oct 21, 2012 11:35 pm
Boanerges4 wrote::thinking: :thinking: My question is that I would like to put some type of bonding agent between the luan on top and the 29 gauge metal that I will be applying. Thanks so much.
Are you talking steal or aluminum? :thinking: It makes a difference. :yes:
Image Image Image
Gage
Images: 28
Postby Boanerges4 » Mon Oct 22, 2012 9:30 am
Aluminum. Maybe if I put two coats of rot dr. that will be sufficient. I just want to make sure that I have all my bases covered. Water and air will go where nothing else does. I have to much time invested to have rot on the roof and have to tear it apart.
Boanerges4
Postby Boanerges4 » Mon Oct 22, 2012 2:18 pm
Another question that I have is about the 29 gauge aluminum. Is it to heavy to use? I have found a source that has 36inch x 12 feet for 28.00 a sheet, thats the cheapest that Ive been able to find it. Ive been able to keep every thing else in check as far as weight so I dont want to overload myself.
Boanerges4
