Vardo plans
Re: Vardo plans
Postby mikeschn » Sat Oct 27, 2012 11:13 am
Andrew,
I agree!
I saw something similar in a larger travel trailer, with 2 pocket doors. The shower is where the closet is in these plans. That made for a rather nice usable area.
Re: Vardo plans
Postby Deryk the Pirate » Sat Oct 27, 2012 12:05 pm
yeah if the bowed part was tied into the roof, Id like to assume it would help divert the drag a bit, has to be better then a flat front with an overhang like I have now. Add 3 windows to the bowed area and a shelf, below it storage accesable from the outside.... the bed would be right next to the shelf and windows and if you put in an appropriate sized window that if you were camping somewhere with power could slide a window ac unit in....I really like this idea....Mike your Awesome!
deryk
Deryk the Pirate
Images: 158
Re: Vardo plans
Postby Deryk the Pirate » Sat Oct 27, 2012 12:08 pm
I had a sailboat once with a similar arangement with the doors and the fiberglass floor rose up 3 or so inches on either side with a shower drain so it could be a shower as well then close the doors it hides the toilet on the left and a sink/showerhead on the right and was a little hallway to the bed area.
deryk
Deryk the Pirate
Images: 158
Re: Vardo plans
Postby droid_ca » Sat Oct 27, 2012 1:33 pm
That's why I have been measuring up all the stuff I have so far that I'd like to stick inside of my trailer..I use the paint program and have drawn up some of the items that will be going inside and I have labeled everything so I can play with the locations of things before I put them in permanently
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Re: Vardo plans
Postby mikeschn » Sat Oct 27, 2012 6:25 pm
Droid,
Those Vardo plans look interesting. Did you notice if the person that did those plans built it yet? Are there any photos of that?
Re: Vardo plans
Postby mikeschn » Sat Oct 27, 2012 7:37 pm
If you make the front of the roof flush with the front wall for aerodynamics... it'll look a little like this...
One other thing, I changed the bay window to a pointy nosed front!
Re: Vardo plans
Postby mikeschn » Sat Oct 27, 2012 9:54 pm
I added a little bit more detail so that we can visualize it better! 8)
Re: Vardo plans
Postby droid_ca » Sun Oct 28, 2012 12:25 am
or
or
or
or
or
or
or
Tjhats all I got for window ideas hope it helps you out
“Fide Canem”
droid_ca
Images: 176
Re: Vardo plans
Postby n0klu » Wed Oct 31, 2012 11:16 pm
mikeschn wrote:Droid,
Not yet I still have to save up enough $$$ to buy the trailer and then the materials can be bought a little each month I have laid it out in a 12' and a 14' trailer design. I am hopeful to get started sometime in the near future.
BTW if you want to use these plan layouts feel free to do so, modify and build one for yourself! My donation to the community.
Michael D. Inman
- The Only Thing Necessary For Evil to Triumph is for Good Men to do Nothing - - Edmund Burke...
"If the First Amendment fails, use the Second one."
n0klu
Re: Vardo plans
Postby droid_ca » Wed Oct 31, 2012 11:30 pm
Welcome aboard n0klu I like the layout of your roof line do you have any other picture of this idea?
“Fide Canem”
droid_ca
Images: 176
Re: Vardo plans
Postby n0klu » Thu Nov 08, 2012 11:06 pm
Thank you for the welcome.
I have developed this plan for a 12' trailer as well as the 14' trailer. To answer you question:
Not yet however they can be made rather easily. I use a CAD program called "Vectorworks" a Macintosh program.
What kind of views are you looking for? I don't know how to do rendering very well.
I used the pitched roof only because it would be easier for me to build (and insulate)... A bow can be substituted but the walls must increase another 10-14 inches to make for the headroom, or a drastic bow would have to be done. Bows are typically +/- 8' on the radii or about 12-14 inches in the bow. looking at the section the bow would be just below (2-3") the inside of the pitched roof and then the thickness of the roof lower still.
Sorry for the lag time in my response.
Michael D. Inman
n0klu
Re: Vardo plans
Postby droid_ca » Fri Nov 09, 2012 2:21 am
Do you know what angles your roof lines are on as for my cabin idea I think that would be about the angle I'd like to go with with the exception of 2 feet how much of a difference is there between your 12 foot and 14 foot design
“Fide Canem”
droid_ca
Images: 176
Re: Vardo plans
Postby n0klu » Fri Nov 09, 2012 3:22 am
droid_ca wrote:Do you know what angles your roof lines are on as for my cabin idea I think that would be about the angle I'd like to go with with the exception of 2 feet how much of a difference is there between your 12 foot and 14 foot design
here is the floor layout of the 12' plan:
6x12' Vardo.pdf
(199.1 KiB) Downloaded 638 times
the kitchenette is a little smaller as well as the closet space.
Here is the dimensions and angles for the 14'... Hope this helps you.
14' single axle trailer Vardo.pdf
(33 KiB) Downloaded 615 times
Michael D. Inman
n0klu
Re: Vardo plans
Postby n0klu » Mon Nov 12, 2012 5:39 pm
6x12' Vardo.pdf
Did they help? :D
Or not? :?
Michael D. Inman
n0klu
Re: Vardo plans
Postby droid_ca » Mon Nov 12, 2012 6:55 pm
goimg over the plans there is one dimension that seems to be missing and that is the actual height of wall that is angled outward But I've been playing around with some ideas I might do a straight wall with no angles as I'd like to keep it as close to a house shape as possible...figure I better spend some time in designing it right the first time instead of ripping it apart and having to do it over again and agian
“Fide Canem”
droid_ca
Images: 176
