Shadow Catcher wrote:I went with a Victron battery monitor http://www.victronenergy.com/battery-monitors/bmv-600s and bmv-602s and one of the read outs is state of charge in percent. It attaches with a standard phone cord to the shunt on the battery. Therefore it would be possible to have the meter in the TV with relative ease and read what is happening. To get an accurate reading you have to measure what has gone into and come out of the battery.
droid_ca wrote:now if you had an electric heater would that be safe to run while towing or is that still a no no
H.A. wrote:droid_ca wrote:now if you had an electric heater would that be safe to run while towing or is that still a no no
If you mean electric space heating within the trailer whilst driving, Sure it could be done plenty safely.
Would not at all be practical in our scope of tow vehicles with small traveltrailers, But could be easily done.
Martiangod wrote:You could switch the spare wire in the 7 wire plug to turn on a 12 volt heater from the TV, then it wouldn't be running off the trailer battery, but your running charging TV instead.
Hmmmm, now something else to incorporate into the trailer...Damn you!!!
slowcowboy wrote:droid, really how hard is it while out beating around the bush in the snow in the winter time.
to pull over and get out and go reach into the teardop and turn a heator on.
I know its the princepal of like remotes and the tv.
but really how much extra wires and stuff do you want to have in a tow vehicle and extra switches and stuff.
its really for me not that hard to just stop and turn a heator on.
slow
but I have found a kit that boosts it up to 140amps.
