225's Teardrop!!!
Re: My teardrop camper build. Another "Weekender".
Postby 225 » Fri Nov 09, 2012 7:38 pm
Ok, decent update.
I went a bought the steel today:
Cut to length:
Squaring it up:
Getting there:
The tongue will retract under the frame:
She'll be rolling tomorrow.
Postby 225 » Sat Nov 10, 2012 3:41 pm
I have got a lot done on the frame. Still a long way to go. I have to brace the tongue. And a few other small things. Basically another day of welding.
Working on it:
She is finally rolling, besides the bunch of bracing I have to do.
Wheels:
More on Monday.
Postby droid_ca » Sat Nov 10, 2012 3:47 pm
Looks awesome your doing a great job
:thumbsup: :applause: :thumbsup: :applause:
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby 225 » Sat Nov 10, 2012 5:13 pm
Thanks, look ok other than I just realized I mounted the axles backwards. So I have to reweld them tomorrow... :(
Postby 225 » Mon Nov 12, 2012 3:35 pm
Well today was kind of productive. I ran out of argon, and paint. Plus it was kind of windy which made welding difficult because it kept blowing my shielding gas away. I would go refill my bottle and buy more paint, but I have to go to work tomorrow. So it will have to wait.
Half of the frame is painted. Also, I have a little bit of welding to do. I tacked up the A frame, but it has to be welded all the way up. Then I have to wrap each end of the center support, because they both will act like a trailer hitch. Since the tongue will slide in/out and the rear will have a hitch receiver.
Doesn't look like I did much, but I flipped the axles, and added another support beam, cut/fitted the A frame, and tacked most of it, welded some. Sanded and painted what I could.
Pics:
Front view. It's upside down too.
Rear view:
It will be another couple weeks before another serious update. Before I can even start working on the cabin, which will go fast, I need a few things.
Door
Hatch hinge
Epoxy
Bed liner
and of course, wood.
Postby aggie79 » Mon Nov 12, 2012 4:20 pm
Frame is looking fantastic! :applause: :thumbsup: :applause:
(I'm jealous of your welding and metal working skills. BTW.)
Postby 225 » Tue Nov 13, 2012 7:03 pm
aggie79 wrote:Frame is looking fantastic! :applause: :thumbsup: :applause:
Thanks Tom.
Re: 225's Weekender.
Postby Junkboy999 » Fri Nov 16, 2012 11:29 am
So what do you think the axle. I modeled the same axle in my cad program and tried them
under my trailer in the virtual world. I think I’ll still go with a 3 inch drop axle and leaf springs.
Man i really need to learn to weld, your frame looks great.
:applause:
Junkboy999
Images: 52
Postby 225 » Sat Nov 17, 2012 8:45 am
Junkboy999 wrote:So what do you think the axle. I modeled the same axle in my cad program and tried them
:applause:
I like the axles. I also wanted them like that because of the center support that goes front to rear. Since both sides will be holding gear/motorcycles.
As far as welding goes, I wouldn't suggest starting with TIG welding.
Everlast makes great machines. They sell a I-MIG200, that you just can't beat. The welding community gives Everlast welders a lot of crap because they are not American made. But They are good machines.
I would buy one, but I am building 2 motorcycles and this camper. So it's just not in the budget right now.
Here is one of my welds from the trailer:
Postby 225 » Thu Nov 22, 2012 9:20 am
So I am working on have almost everything together that I need to build the cabin at one time and not wait on parts. Plus I have to finish welding up the frame too. Which is taking the longest because I am doing so much extra stuff that most people don't do. Usually they just buy a trailer and bolt the cabin to it.
So here is what I got this week. By time I come in from work, it should all be there.
4 hinges. 2 for the door, 2 for the hatch: $49.23
2 new RV windows: $197.41
2 awesome fenders: $83.42
Metal taillight holders: $39.98
Mounted:
Door plunger: $10
Door lock: $38
And 10 of these for hold downs in different spots: $22
Right now TCI:$1770.04
Postby bigblockbarry » Thu Nov 22, 2012 9:57 pm
I built my own frame too,and it seemed to go the fastest.When it looked halfway done I only had 75% more to go. Keep it up.
bigblockbarry
Postby 225 » Fri Nov 23, 2012 9:44 am
bigblockbarry wrote:I built my own frame too,and it seemed to go the fastest.When it looked halfway done I only had 75% more to go. Keep it up.
I agree. But I wanted to build the trailer my way. So it's taking a little time.
Today I bought:
2- 2" round lights for the taillights: $14.95
And 2 fender lights: $14.95
TCI: $1800
Postby 225 » Thu Nov 29, 2012 6:08 pm
I finally finished up my frame. I had to do a couple of welds on the bottom, then flip the frame over and weld everything else. Then I had to make the tongue extension.
Also, everything has came in the mail. I picked up a bunch of hardware and the Kreg pockethole thing. And a few nick knack things. More to come in a couple of days. I will start the wood working tomorrow.
Postby Lonnie Mac » Thu Nov 29, 2012 6:50 pm
Looks great!! I hope to be right where you are now in at least a year!
Lonnie Mac!
AleNuts Radio and home of Brutus "Ten"!
President of the Brutus Ten Cult...
Build Thread (Almost): http://www.tnttt.com/viewtopic.php?f=50&t=53596
Lonnie Mac
Postby 225 » Fri Nov 30, 2012 6:10 pm
Thanks. I've been working hard at it for a while now. When I come back in from work, I'll build the cabin. And I think the cabin will go a lot faster than the frame has.
Today, I have been working on the fender, and rack outside the fenders. The boxes will have aluminum diamond plate in them. Tomorrow, I will finish the front ones. Then mount the fenders and wire up the trailer. Hopefully as of tomorrow, I'll be done with this phase.
Fender mock up:
Fender mounts:
Mounted:
