Romex clamp
Anything electric, AC or DC
Romex clamp
Postby Rolly » Mon Oct 15, 2012 8:06 pm
I am installing a new breaker panel in my 1971 trailer. Can I safely put 2 romex cables through a romex clamp/ strain relief?
Rolly
Rolly
Re: Romex clamp
Postby Fishingtomatoseed » Tue Oct 16, 2012 8:19 pm
Rolly wrote:I am installing a new breaker panel in my 1971 trailer. Can I safely put 2 romex cables through a romex clamp/ strain relief?
Rolly
By code, Nope. Would it be safe, up to you. Can you make a new hole and use a 2 pice clamp?
Fishingtomatoseed
Images: 9
Re: Romex clamp
Postby bc toys » Tue Oct 23, 2012 10:58 am
go ahead there is no inspection on your trailer its safe as long as you get the insolation inside the clamp
bc toys
Images: 42
Re: Romex clamp
Postby cpinetree » Fri Nov 09, 2012 7:52 pm
Yes, I do purchasing for an electrical contractor the following are NEC compliant for multiple cables,I am sure other manufacturers romex connectors are made to handle multiple cables also.
Bridgeport #566-DC2 suitable for use with (1) 14/2 to 10/3 NM-B cable or (2) # 14/2 or 12/2 NM-B cables.
http://www.bptfittings.com/Catalog/CatalogFamily.aspx?CategoryId=23&FamilyId=117
Arlington makes a plastic black button part number NM94 fits 3/8" (1/2" trade size knockout), below are the cable ranges from their specs.
http://www.aifittings.com/catalog/non-metallic-fittings-and-supports/black-button-non-metallic-push-in-connectors/NM94
Cable Ranges:
NM94
One 6/2 - 14/2
One 12/4
Two 10/2 - 14/2
One 10/3 - 14/3
One 10/2 and One 14/2
One 12/2 and One 14/2
One 10/2 and One 12/2
Two 14/3
Two 12/3
cpinetree
Images: 18
Re: Romex clamp
Postby bdosborn » Fri Nov 09, 2012 8:54 pm
I didn't know that, I would have guessed no on 2 cables. Thanks for the Link! :thumbsup:
Images: 806
Re: Romex clamp
Postby Fishingtomatoseed » Sat Nov 10, 2012 9:52 pm
Didn't know that it either. That is the first thing that and inspector looks for in a new house. After you fell one or two inspection because of it you don't do it anymore.
Fishingtomatoseed
Images: 9
Re: Romex clamp
Postby cpinetree » Sun Nov 11, 2012 7:22 pm
Fishingtomatoseed wrote:Didn't know that it either. That is the first thing that and inspector looks for in a new house. After you fell one or two inspection because of it you don't do it anymore.
The Arlington black buttons are made in 1/2" + 3/4" trade size and handle a wide variety of cable sizes, either single cables or multiple cables of different sizes. Just leave a copy of the spec sheet with your panel, your local inspector will get the word around. They are perfectly legal and designed for the purpose.
I think in a trailer I would prefer the clamp style like the metal Bridgeport, but in a house where the panel is not bouncing all over the Arlington product is quick, inexpensive, and easy.
cpinetree
Images: 18
Re: Romex clamp
Postby Rolly » Tue Nov 13, 2012 12:54 pm
Thanks for the info cpinetree. the Bridgeport looks like a 1part# solution for a lot applications. Now to find them in less than 100 quantities.
Rolly
Rolly
Re: Romex clamp
Postby cpinetree » Tue Nov 13, 2012 7:39 pm
Rolly wrote:Thanks for the info cpinetree. the Bridgeport looks like a 1part# solution for a lot applications. Now to find them in less than 100 quantities.
Rolly
Graybar http://www.graybar.com/ in my area handles Bridgeport fittings.
Most any electrical supply house near you will will sell over the counter to homeowners (most all break boxes / sell individual units). If not call your local electrician or go by their shop, they will likely give you a few.
Don't get hung up on the specific manufacturer, most every one I have ever seen is approved for 1 or 2 14/2 or 12/2 romex cables. If you are using a different combination of wire, such as a 14/3 with a 14/2 then check the manufacturers website for the specs.
cpinetree
Images: 18
Re: Romex clamp
Postby Rolly » Tue Nov 13, 2012 8:49 pm
If I can find the bridgeport I will use them, according to their web site they are made in USA.
Rolly
Rolly
Re: Romex clamp
Postby bc toys » Tue Nov 13, 2012 11:02 pm
if 1-2 is all you need you can get them at the big Orange store or you could find a service truck of a Electrical shop he will give you some most of the time.
bc toys
Images: 42
Re: Romex clamp
Postby Rolly » Thu Nov 15, 2012 1:19 am
The Halex brand clamp I have from the orange store is speced for 2 14-2 but only 1 12-2. I am using 12-2
Rolly
Rolly
Re: Romex clamp
Postby Rolly » Thu Dec 06, 2012 4:40 am
cpinetree
Have you ever used the Bridgeport 556s? They have nice specs but they don't look like a good idea for mobile application to me.
Rolly
Rolly
Re: Romex clamp
Postby cpinetree » Sun Dec 16, 2012 9:15 pm
Not sure what the 556 is. Maybe you mean the 565-DC2? If so i think they would be fine in a trailer.
cpinetree
Images: 18
Re: Romex clamp
Postby Rolly » Sun Dec 16, 2012 10:35 pm
cpintree
I owe you an apology. When a person "In the trade" takes time to share their knowledge and experiance they should not get a snippy response like i gave.
In my defense, I cornered a box of 566-DC2 clamps grabbed some NOS 12/2 romex, started to install it and discovered the insulation on the black and white wire rubbed on the clamp. I was worried about vibration rubbing through the insulation. Then to my regret i posted my snippy response. Later I tried some more current romex and the sheath went clear through the clamp, no problem. See the picture below
100348
I have just under a hundred 566-DC2 s left over.
Rolly
Rolly
Return to Electrical Secrets
