The main points are that you are still doing things and you remain optimistic.
PS. Loved your BBQ/DO tip (see below) for Droid. It looks like that one out does the DO Satellite-walker table!
viewtopic.php?f=54&t=53091
S. Heisley wrote:.
The main points are that you are still doing things and you remain optimistic.![]()
bobhenry wrote:I took 3 of my 4.5 volt 99 cent led flashlights and hooked them in parallel to see if they would work with the 12 volt power circuit and yes they did !
Wobbly Wheels wrote:bobhenry wrote:I took 3 of my 4.5 volt 99 cent led flashlights and hooked them in parallel to see if they would work with the 12 volt power circuit and yes they did !
I want to use them for under-cabinet and maybe courtesy lighting but was going to solder in a 1/4W resistor when I figure out a housing (prob a piece of pvc conduit).
I'll have to check it out and see if mine will take 12V too. Thx Bob !
I am not sure at this time if they will remain 120V AC or if I will opt up for a ,currently rather expensive, 12 volt standard base LED bulb.
It didn't like being left in the cold and was fogging up a bit
wired with 2 hot feeds and 2 grounds one of each was input the other was pass thru to the next light
I like the extension cord for wire: waste not, want not !
