I love the rear galley in teardrops. It seems that outdoor cooking is real camping. That’s why I’m calling my design a Camper instead of a Recreational Vehicle. I have a kerosene single burner stove inside but its primarily for heat rather than cooking. I plan to use it for making coffee or heating up a can of soup or beef stew on cold/wet/rainy days. But the real cooking is done outdoors just like a primitive camp. But it’s not primitive at all as you shall see.
My three stoves are Butterfly A822 all aluminum single burner kerosene types that only cost $80.00 each. I don’t plan on using propane at all.
Lighting too is kerosene and also from Butterfly.
My design barely has any electrical system at all…Just the trailer lights and brakes powered by the tow vehicle plus a shore power cord to run the window style air conditioner if I want to use shore power or a small generator. There is also a solar panel on the roof to maintain the charge for a pair of deep cycle batteries which are only for the 3 fantastic fans mounted in the roof. Simple, and since I’m no electrician, easy too.
- SCENE 1.jpg (217.8 KiB) Viewed 4398 times
The Trailer
Flat top and flat front. Wind deflection will be on the tow vehicle.
Custom built with one vertical slide window on the right rear and a door positioned 5’1” from the front corner to allow the interior space forward of that to enclose a front storage locker with 2 doors on the front and to the rear of the locker a 3’ x 5’ wet head and a curtained off closet.
The rest of the interior is laid out similar to a Gypsy Vardo with an athwart space queen sized bed and a lounge/dinette with slide out table. In the corner near the shower door is the interior stove above the window type air conditioner.
Under the bed there are several drawers for clothing and miscellaneous items and to the rear of the drawers under the bed is a storage locker accessed from the outside for storing hunting and fishing gear.
- scene 3.jpg (224.82 KiB) Viewed 4387 times
Also under the bed is a 3’ x 5’ slide-out table. Best of both worlds…a lounge with two settee’s or a dinette/desk when needed.
Awnings
Both sides of the trailer have sheet metal awnings that lift with support from pneumatic lift supports similar to what is found on larger SUV’s. Underneath each awning is foam insulation which gives them rigidity and cooler shade below. They also serve as extra security to keep out intruders while you’re away from the trailer. The left awning serves as a carport for the tow vehicle in case of a hail storm.
I can have both awnings built locally for the price of a single canvas RV awning.
Forward Lockers
The tongue of the trailer will have diamond plate standing place for accessing the locker doors. The upper section is for dry storage of hanging clothes etc. The lower section is for general storage and two deep cycle batteries in the center (mentioned above). The floor and shelf are both covered with charcoal indoor/outdoor carpet.
