Next weekend I should be able to finish the roof skin, build the A/C mount, and start applying Bondo over the seams and screw heads.
Vedette wrote:Jeff
Don't use bondo. It is talc based and absorbs moisture.
Use a fiberglass based filler, like duraglass or everglass (short strand).
It is harder to sand, especially if you let it sit too long before sanding, but it will dry hard as a rock and is waterproof.
Good Luck
& Good Roads
Brian
