A toyhauler cargo conversion
Re: A toyhauler cargo conversion
Postby pvangel » Thu Dec 27, 2012 1:49 pm
Ordered the floor in gray, figured the lighter color will make it seem bigger and brighter.
Also ordered, FantasticFan, regular roof vent,2- 12" round windows, 36x22 exit window,and a cool folding aluminum table that hangs on the wall but can be moved outside and hung on the exterior as well.
pvangel
Postby H2Nut » Thu Dec 27, 2012 5:55 pm
Got more details about the folding table that works inside and out. That is what I have been looking for.
H2Nut
Images: 22
Postby pvangel » Thu Dec 27, 2012 7:30 pm
Ebay, # 400373656066
Folds down to 4" off the wall
Rotates on nylon washers
Extra set of mounting buttons included, mount set inside for travel and set outside for workstation
All hardware included
Rated at 300lbs
Mounts at 4' centers
Table size 18"x46"
Made from .090 aluminum
Manufacture offers 5 year warranty
$99.00 There are 2 smaller ones as well
pvangel
Postby H2Nut » Thu Dec 27, 2012 9:38 pm
Thanks for the information - will have to check it out. Curious - :roll: - from looking at the design wonder if you could mount it upside down and have a work surface with a lip to keep from loosing small parts/items.
H2Nut
Images: 22
Postby pvangel » Fri Dec 28, 2012 9:35 pm
Parts are starting to roll in! it amazes me that I can order something on Wednesday and it's at my door Friday....
Fold out work table showed up and I have to say is very well made.
Fantastic Fan and 1 of 2 of the "porthole" windows,
Might get some stuff done this weekend if the snow is not to bad!
pvangel
Postby roadinspector » Fri Dec 28, 2012 10:28 pm
pvangel wrote:Parts are starting to roll in! it amazes me that I can order something on Wednesday and it's at my door Friday....
The UPS and Fedex fairies have been working overtime!! :delivery:
Dadgum it! I cut that board 5 times and it's still too short!
2001 quad-cab Dodge Cummins 3/4 ton camper special, 16x7x7 CT work in progress toyhauler, 01 HD Ultra Classic, 98 HD Heritage Softail, 88 HD 1200 Sportster. viewtopic.php?f=42&t=51510
roadinspector
Images: 127
Postby pvangel » Sat Dec 29, 2012 2:52 pm
Nothing better then seeing one of there trucks backing up the driveway!
I sent this sketch off to a guy that builds diamond plate boxes,
Which will be mounted to the front of the trailer to hold this,
So it will be close to the propane tank and I will run the water under the trailer and come up into the bottom of it.
pvangel
Postby pvangel » Sat Dec 29, 2012 5:29 pm
Snowing and cold out so I measured out all the insulation left to go in and cut it in the comfort of the garage, even cut out the roof vents and lights so all I have to do is stick it up in place and I will have a template ready to cut out the vents in the roof.
Even made some "custom" corner insulation for the nose of the trailer.
pvangel
Postby revorunner » Sat Dec 29, 2012 11:16 pm
Excellent job Pvangel. Looking forward to more pics as your work progresses. :)
revorunner
Postby roadinspector » Sun Dec 30, 2012 11:17 pm
Ditto!! :thumbsup:
roadinspector
Images: 127
Postby Dirtclod » Tue Jan 01, 2013 6:23 pm
Hey PVangel
New guy here but I just started on building a toy hauler as well. I have been following your build and i have stolen, umm I mean borrowed several ideas from you. Thanks
Quick Question .. Is that an EcoTemp outdoor type water heater? Are you planning on an outdoor shower too? Or are you planning on running the hot water back into a "indoor shower" ?
Dirtclod
Images: 9
Postby pvangel » Tue Jan 01, 2013 6:35 pm
After weighing the costs, price per cubic inch, use of space, weights, time involved, finishes and of course the coolness factor I have decided on these cabinets,
6' Base cabinet
6' upper cabinet
It is a bit of a change of plans for me but I think it will work, haven't ordered yet but probably will after I sleep on it.
pvangel
Postby pvangel » Tue Jan 01, 2013 6:43 pm
Dirtclod wrote:Hey PVangel
I have stolen many ideas here, I look at it as flattery not plagiarism...
I only intend to have an outdoor shower, it takes up to much space on the inside and in general I am at a race track so just shower in my underwear after racing and nobody seems to mind( It is not a pretty sight I have been told but don't really care) . I ordered the cabinet yesterday that will house the Ecotemp, so everything will be in a sealed box outside the trailer.
pvangel
Postby pvangel » Wed Jan 02, 2013 8:46 pm
After sleeping on it and re-measuring the trailer these cabinets are to big, gotta rethink it...
Floor tile showed up, looks nice!
pvangel
Postby pvangel » Fri Jan 04, 2013 8:09 pm
Parts keep rolling in, just have to get the time (and good weather) to start assembly.
I ordered this door knob to try and make work because a normal rv door latch would hit the lock bar, we'll see how this works.
Ceiling material, pvc wainscoting. I thought it would be easier to instal than 4x8 sheets.
And the second roof vent, no fan.
I should be able to work on it Sunday...we'll see.
pvangel
