A toyhauler cargo conversion
Re: A toyhauler cargo conversion
Postby pvangel » Sat Jan 05, 2013 5:07 pm
My E-track pieces today,
Should fit flush to the tile,
So I had to figure out how the bikes would fit, 5 work on paper but I think 4 is it.
I think the angle setup was the best but have to check one more time,the insulation is my base cabinet mock up.
I have to see still what works best...
pvangel
Postby pvangel » Sat Jan 05, 2013 5:15 pm
In preparation for installing the roof vents I cut 2-1/2" plywood backer pieces so I have something to anchor the vent to.
I glued them in place so I can use as a guide and cut from the inside and the screws will anchor it permanently,
Weather dependent I will cut the roof open tomorrow.
pvangel
Postby hankaye » Sat Jan 05, 2013 8:02 pm
pvangel, Howdy;
I send some good thoughts your direction .... :worship:
hank
hankaye
Postby pvangel » Sun Jan 06, 2013 5:02 pm
Thanks Hank!
It was a beautiful day in NY for January, clear skies and 45deg. I'll take it because I got a ton done today.
It's always scary to cut a hole in a perfectly good roof, but I measured twice (more like 5 times) and cut once.
Lots of GE Silicone,should be water tight.
DONE! Black one is a regular vent and the white one is a fantastic fan.
I'm glad I'm past that.
pvangel
Postby pvangel » Sun Jan 06, 2013 5:24 pm
Moved on to windows, have to make hay when the suns shining.
I cut out temporary plywood templates out of the 14"x14" roof vent cutouts so I could mark the holes and then use as spacer blocks,
Had to use duct tape to protect the skin because I was out of blue tape...of course all the glue stuck to the metal when I pulled it off so I had to clean before setting the window.
In!
They are set to go between the base and upper cabinets.
Looks good!
Still waiting on the big window and ripped out most of the wiring I did because I am making the base cabinet smaller so i have to re do it plus I wasn't happy with what I had done.
pvangel
Postby roadinspector » Sun Jan 06, 2013 7:04 pm
Good progress. I was aprehensive before I cut my first hole too. Only one chance to get it right. Looks good!
Earnest
Dadgum it! I cut that board 5 times and it's still too short!
2001 quad-cab Dodge Cummins 3/4 ton camper special, 16x7x7 CT work in progress toyhauler, 01 HD Ultra Classic, 98 HD Heritage Softail, 88 HD 1200 Sportster. viewtopic.php?f=42&t=51510
roadinspector
Images: 127
Postby H2Nut » Sun Jan 06, 2013 7:23 pm
Great progress! Windows look :thumbsup: good.
H2Nut
Images: 22
Postby Gonefishin » Sun Jan 06, 2013 7:42 pm
Looks like masterful construction to me. And speedy too! :applause:
Gonefishin
Images: 119
Postby hankaye » Mon Jan 07, 2013 1:34 pm
pvangel, Howdy;
Nicccce! Looks like you almost had to much fun!
Question;
The top picture with the saw on the roof, Is it Wood with a rubber coating
thought on these kinds of trailers the roofs were metal. Am I missing
something???
Reason I ask is if the roof has a EPDM (?) rubber roof, silicone is NOT
compatiable. Dicor is the prefered sealant.
Just being courious...
hank
hankaye
Postby pvangel » Mon Jan 07, 2013 3:49 pm
Hank, It is a regular one piece metal roof, must just be the picture but thanks for watching out!
pvangel
Postby pvangel » Mon Jan 07, 2013 5:49 pm
It's a joy to get home and see a package at the front door!
The picture/escape window showed up today,(not sure who the old guy is in the reflection though?)
Of course the flange got bent, I assume in shipping.
Some pliers and an old sock so I didn't scratch it and good as new.(wait it was new?)
The garage is overflowing, have to start doing more but between work and winter...it ain't easy!
pvangel
Postby pvangel » Mon Jan 07, 2013 6:11 pm
I appreciate all of the great ideas and feedback I have gotten on this site, some great minds that seem to think like me? Thanks!
And I forgot to say in the beginning of my thread that I am a 53 yr old vintage mx (vintage body and bike) racer so use the trailer for daily rides as well as races throughout the Northeast. From Maryland to Massachusetts with stops in Penn.,NY,NJ,Ct.and West Virginia
Penn,
Conn.
NY,
Another track in Conn.
Mass.
NJ
My son and I in Md.
Ct.
pvangel
Postby hankaye » Mon Jan 07, 2013 11:13 pm
pvangel, Howdy;
Think I saw your plywood backing and that 16 tooth blade in the saw and
..... well ya'll know the rest.
I rode for many years, nut-in fancy just an old Hog... That track in Md. Is that
Budds Creek ??? I used to work for a contracter down in Lexington park, Md.
At the Test Pilot School, helo shop.
hank
hankaye
Postby pvangel » Tue Jan 08, 2013 8:40 am
Yep, Budds Creek Md.!
pvangel
Postby pvangel » Tue Jan 08, 2013 8:16 pm
Ok, Back to work...
So if I get one of these,
Can I charge the rv battery off my truck battery while driving, I know I have to change my 4 prong flat plug to a 7 prong round to take power from my truck but is there a 12v input on one of these? I don't want to spend money on one if I just need to have a battery Tender hooked up to my EU1000 to keep it charged.
As I said, electrical is my weakness...
pvangel
