Adding insulation and wood to interior: 1947 Tourette
Re: Adding insulation and wood to interior: 1947 Tourette
Postby KCStudly » Sat Jan 12, 2013 3:35 pm
Are cargo trailer door locks even designed to open from the inside? Forgive my ignorance.
I special ordered thick wall door latches to accommodate my 1.5 inches of insulation (plus 5mm ply inside and canvas skin outside... total 1-3/4 inch wall thickness... estimated... foamie hybrid design) and the screws that came with them were too short for the spec. Arrgh! :x
Postby GuitarPhotog » Sun Jan 13, 2013 12:29 am
The OP is asking about a classic 1947 Tourette teardrop, it's not a cargo trailer.
To address the question, I haven't solved it yet in my trailer, so I've got this 30" square of un-insulated aluminum in the side of my cabin :(
I'm thinking of abandoning the foam insulation for the door and going with a thin piece of wood covered with the hull liner that the rest of the interior is covered with. No R-value, but better to touch than a slab of cold damp metal.
<Chas>
GuitarPhotog
Images: 55
Postby KCStudly » Sun Jan 13, 2013 12:47 am
GuitarPhotog wrote: The OP is asking about a classic 1947 Tourette teardrop, it's not a cargo trailer.
Oops. My bad. I guess my message is still valid, though. Thick door latches are available. Maybe not vintage, but neither is hull liner, so...
Postby Gage » Sun Jan 13, 2013 1:00 am
Deleted my posting because apparently I offended KCStudly.
Image Image Image
Gage
Images: 28
Postby KCStudly » Sun Jan 13, 2013 2:43 am
If he was trying to do a strict restoration he would not be adding insulation and interior ply. :thinking:
By my way of thinking that indicates that he is doing some modifications and was asking for help with adapting door latches to this new thicker wall condition.
Maybe I was helping by trying to provide the OP some information that he may not have been aware of, maybe not. I don't think there has been enough information given to make that call.
Things are not always so cut and dried.
Try a little tenderness.
Peace.
Postby burlesot » Sun Jan 13, 2013 10:15 am
Yes
I am planning to add insulation to my teardrop; I am not trying to put it back to its original state. I want to warm up the cold interior with foam and a wood skin.
It sounds like there are thicker door locks available then right?
Where can you purchase these!
T
burlesot
Images: 62
Postby KCStudly » Sun Jan 13, 2013 10:40 am
Have a look at this thread; I'm sure there are others, too.
Show Me - Door Handles and Latches
Postby burlesot » Sun Jan 13, 2013 11:11 am
Thank you!
burlesot
Images: 62
Postby doug hodder » Sun Jan 13, 2013 9:11 pm
Just google RV door handles/latches. I picked one up with a deadbolt for my new build for I'm thinking like 30$. It's a paddle handled latch. As a side bar...you can also attach furring strips on the interior of your trailer using some wood strips, sealed with a urethane so the tape will stick really well...then attach them to the side using some 3M VHB foam tape. No holes for attachment. It's used quite a bit in the large truck industry for cab construction. Just make sure you get some warm temps on the outside material when attaching. For what it's worth. Doug
Postby burlesot » Sun Jan 13, 2013 10:09 pm
Doug
Really appreciate it.
T
burlesot
Images: 62
Postby burlesot » Sun Jan 13, 2013 10:13 pm
Doug
Thinking a bit more about your strip idea
Would that be a better idea over simply adhering the wood 'panels' directly to the foam insulation? I can see that it would then give you something to screw into, right?
Thanks for your insight.
T
burlesot
Images: 62
Postby doug hodder » Mon Jan 14, 2013 10:17 am
burlesot wrote:Would that be a better idea over simply adhering the wood 'panels' directly to the foam insulation? I can see that it would then give you something to screw into, right?
T
That's how I'd do it, all panel seams would have something other than foam behind them. Doug
Postby burlesot » Mon Jan 14, 2013 9:52 pm
Doug,
Thanks. I should have some interior images tomorrow evening; I'll use those to start planning. This is killing me! Can't wait to get my hands on my teardrop!
T
burlesot
Images: 62
