Top down
Top popped up. The rear of the top portion folds down to become the foot area of the bunks. This allows the top to be within the Jeep's footprint when retracted.
redveloce wrote: I soaked a rag in thinner, just so the rag was moist but not dripping wet, and wiped the surface of a test scrap of foam. This caused a thin layer of the surface to melt, but no deformation or holes. I then pressed a small scrap sheet of ABS onto the surface of the foam. The plastic became nearly impossible to remove after only a few seconds, without even having sanded the ABS first! Trying to pry the plastic from the foam, it would slowly 'goo' off of the foam with quite a bit of effort while the foam was still melted, but once it set up, there was no way to remove the abs without destroying the foam!
KCStudly wrote:Very interesting. Do you think that you can scale that process up to 4x10 and still achieve uniform results in the allotted time required to get a whole wall or roof wetted and covered? How about the initial tack; is there any forgiveness for initial placement of the panel, or do you have to get it right on the first go?
atahoekid wrote:Instead of wiping/mopping it on, could you spray it on evenly and thinly enough. Maybe using a garden sprayer or something similar? Intriguing idea... most of the best ideas come about because someone is willing to experiment. Can you answer a few questions for a plastic newbie. Where can you buy ABS plastic and is there another name we would know it by, what is this type of ABS normally used for?
KCStudly wrote:And what size sheets does it typically come in? Can we get 4x10?
Effectively the frame of his is rounded corner AL angle irons welded at the corners with panels glued into them to make the sides. The panels are pre-made composite panels.
This is a quick detail for the box corner I designed showing both the lifting top and the base in a 3D cross section. Lifting top has the curved corner for the outside and a angle iron for the inside. The base has both inside and out as angle irons. The red pieces are delrin plastic glides, and likely need to be thinner to prevent binding. The panels are 1" thick AL/foam/AL composite panels. Their skins will be on the order of .032" thick. The outside curved corner can be formed from a 1/8" thick sheet AL plate. No need for a custom extrusion of that shape. The panels will be glued to the outside corner pieces first. Then the inside corner angle irons will be glued in place to finish off the corner. The inside angle irons are not welded to the frame. They are only glued in place.
redveloce wrote:FRP skins...all seem to say they're not for exterior use. Not sure what ill effects there would be if you used them on an exterior though.
Wobbly Wheels wrote:redveloce wrote:FRP skins...all seem to say they're not for exterior use. Not sure what ill effects there would be if you used them on an exterior though.
They probably use an ortho ('general purpose') resin in the gelcoat (or no gel at all) because it's quite a bit cheaper than using vinylester resins the way you do in the outer layers on a boat hull.
Nothing a coat of paint won't seal.
Junkboy999 wrote:I think even the corners can be rolled at home if you make a die set for a cheap metal forming machine. Not sure
how you would cap the three corners where they come together.
Partially. I'd thought of doing a hard sided pop-up before, but was thinking along different lines. I was thinking of hard sides that would fold down, and not of the box that lifts.Junkboy999 wrote:So is that what gave you the idea of making a Triple pop-up camper in your other thread?
Users browsing this forum: DrAlvarez and 12 guests
