Finally got a chance to write up the work so far. Hard to believe I've only been working on it 4 weeks, with most of that only on the weekends. I was expecting much slower progress based on many of the other posts. Granted, I'm probably not working at the level of perfection that most others are.
Now, to figure out uploading pictures. I think I saw a how-to somewhere on that in the forums. If not, I think I'll be able to figure it out based on the error message I got when attempting the initial uploads
Week 1
Bought the lumber. Highly recommend finding a specialty lumber shop. For Austin, that was
http://www.finelumber.com/I was amazed at the quality of wood (it was straight!) and their selection of sizes tha the big box stores didn't have. 4x10 and 5x5 plywood was found in abundance
This weekend, I cut the side walls, assembled the floor, and waterproofed the floor.
I took two 5x5 1/2" baltic birch sheets and cut them to size to fit inside my flatbed trailer (keep in mind my TTT will be removeable, so no permanent mounting to trailer frame). On top are 2x2" supports on the sides and front. No 2x2 on the back to allow the hatch to close. For extra strength and waterproofing, I put a piece of thin lauan across the seam of the 5x5s, similar to the inside ceiling recommendation in the generic benroy.
The guy at Lowes convinced me to use a solid deck stain rated for foot traffic to seal the bottom of the floor. Hopefully it works.
Week 2
The spars are cut and glued together where needed for extra strength. I misread the generic benroy plans, so the hatch hinge point became 2 of 2x2"s glued together - ought to be strong enough. I also made an extra beefy front spar that will act as the lift point for removing the camper from the trailer.
Preassembled the roof vent framing for easier installation later. I'm not planning on using a roof vent, but wanted the option for later. I will run wiring to it just in case. I'll probably put in a dome light and computer fan in that spot.
Cut the hatch ribs. I traced the un-notched sidewall on the rib plywood first, then cut 8 ribs. Two doubles on the sides of the hatch, and then four on the middle. I added an extra to the benroy plans since I'm a little wider.
Week 3
Cut the notch for the hatch weatherstripping. I went with 1/4" after playing with the weatherstripping for a while to see how much it compresses. The recommendation in the benroy plans would have been too much for what I had.
Floor, walls, and spars all put together.
Glued the roof 5x5's together with a strip of lauan for strength.
Added an extra sideways spar where the roof 5x5 seam is. Since I added a piece of lauan to the underside of the roof, had to drop this spar by the thickness of the lauan
And, the hardest step to this point, attached the roof to the camper. Put PL Premium on all the sidewalls and spars, and got help to place the 10ft long roof on. Had a terrible time lining things up, so I think most of my glue didn't stay where I needed it. Used an air powered stapler to keep the roof in place.
Still haven't figured out how it happened, but there are several gaps between the sides and roof. Will be filling them with adhesive later for strength and extra waterproofing.
I departed from the benroy plans here and did the roof before the inside ceiling. The thought here is that I want to make it usable sooner, and I'll be spending a good bit of time on the inside with work that can happen while the various waterproofing coats dry. Since I'm planning removable cabinets/galley, I shouldn't have an issue loading the ceiling in from the back later.
Filled all the screw and staple holes with bondo lightweight filler. Had never used this before, and was frustrated by the quick hardening time. Wound up mixing several batches to be able to fill all the holes.
After the roof glue set overnight, I used a flush cut router bit to trim the roof overhang. Had never used a router before, and I was amazed at the simplicity. I wouldn't want to try to trim the overhang without one.
Also stained the inside. The birch sidewalls took the stain quite nicely, but the baltic birch floor didn't take it as well. Will have to add a second coat eventually.
Week 4
Started building the hatch frame. Realized my build to this point must have been pretty sloppy. The top of the hatch is over 1/2" narrower than the base, and the side walls aren't as symmetrical as I thought. Glad I didn't precut everything to length. It's good to have seen the several posts saying soemthing to the effect that it's not about not making mistakes, it's about being good at hiding your mistakes
I started by cutting the top horizontal, then put the doublewide sides in place. I then noticed the sides weren't quite long enough. Happily, a 1x2 under them was just the right size to get everything to line up. I adjusted the benroy plans to have the bottom horizontal under the side ribs rather than between them, and it all lined up. My main concern was maintaining the 1/4" notch reveal (my side ribs needed the 1/4" showing the entire way) to have the right amount of weatherstripping compression once the roof is on the ribs.
Since the hatch wasn't symmetrical, I did a lot of trial and error cutting of the other ribs' lengths to get them sized properly
Ribs are all glued and screwed, and will need cross braces on the next build day.
Sanded the bondo hole filler
Started making the inside door jamb. I'm afraid to try the bent aluminum T molding for the door stop and waterproofing, so I'm following the other ideas of a trim around the inside of the door that will hold the weatherstripping. I cut a 1/4" ply shim flush with the door, and a 1/2" ply stop smaller than the door opening (enough smaller for the stripping to get wider when compressed)
Used an 1/8" roundover router bit on the exposed door jamb parts to get rid of the sharp edges. Also went over the root where it meets the side walls. I've read a couple times that fiberglass doesn't like sharp corners, so I'm hoping this helps enough to prevent issues there. Didn't go more than 1/8" since the roof is only 1/8" ply
Realized this week that I shouldn't have stained the interior yet. I should have waited for the door jamb to be installed. I'm hoping that I don't make the walls look terrible as I stain the jamb. Maybe I'll stain the jamb before it is installed - but something feels like this will be more difficult to fit the jamb just right before some part of it is screwed in.
