The Bummer offroad build
Re: The Bummer offroad build
Postby Ben » Sun Feb 24, 2013 9:28 pm
Word of wisdom. Plan your galley hatch thoroughly make your cuts when they are on the bench not installed on the frame!! When on frame it's much harder!! Don't ask why! Lol. I've been stuck messing with the hatch for a couple weeks now and I have to keep walking away.
Going broke quick fixing a bad start!
Ben
Images: 221
Postby Silvrzuki77 » Mon Feb 25, 2013 8:14 pm
Why? Lol i was thinking about that today. Are you cuting that 3/8th piece off also? I am going to use alder wood for the interior little price but should be nice.
Silvrzuki77
Postby Ben » Mon Feb 25, 2013 9:19 pm
No I cut a 2" lip out to make a hatch like Steve Frederick in his builds.
Ben
Images: 221
Postby Silvrzuki77 » Tue Feb 26, 2013 11:40 am
Yeah i was thinking that was a better way of doing it
Silvrzuki77
Postby Ben » Tue Feb 26, 2013 11:49 am
Read and plan accordingly!! Cut a pattern first sand to desired liking and them cut each one at a time. Over size your rough cut then use router with pattern bit to shape to final size with the pattern you made. That way they are all the same and fit perfect!
Ben
Images: 221
Postby Silvrzuki77 » Wed Feb 27, 2013 5:11 pm
What do you guys think about this hatch cut out? Its approx 1 3/4"
Sorry its faint
Silvrzuki77
Postby KCStudly » Wed Feb 27, 2013 5:22 pm
Looks good.
Consider adding a small radius (1/2 to 3/4 inch) in the corners at the top and where the radius transitions to the vertical rear, rather than a sharp notch. Small detail that adds both strength and eye appeal.
Postby Ben » Wed Feb 27, 2013 5:53 pm
I would have to agree with KC I would round the points off for 2 reasons 1 looks and 2 when you cover it that might tend to be a prolbem area ie would you break a seam or trim or ?.
Ben
Images: 221
Postby Ben » Wed Feb 27, 2013 6:00 pm
If you look on page 17 of the generic benroy plans it shows a 19" radius that follows the 48" radius I don't know if that's the pattern you were following. Just a thought. But the main thing is if that's what you like that's the main thing!
Ben
Images: 221
Postby Silvrzuki77 » Wed Feb 27, 2013 6:06 pm
Copy that guys! Ill post up with a different rendition soon. Want to make it bombproof!
Thanks again for the input!!!!
Silvrzuki77
Postby Silvrzuki77 » Wed Feb 27, 2013 6:17 pm
New radius at hinge and went for 2" instead not going to cut it out for a bit might as well do some more reading first
Silvrzuki77
Postby Oldragbaggers » Wed Feb 27, 2013 6:57 pm
This is an awesome build. I'll bet you could start a business just building those frames and make a small fortune. Very impressive work.
Life is sooooo good.........
Sail...camp....bike...repeat
Becky
Oldragbaggers
Images: 331
Postby Silvrzuki77 » Wed Feb 27, 2013 7:06 pm
Lol thanks, frame was pretty easy now i have no idea what im doing lol
Silvrzuki77
Postby Ben » Wed Feb 27, 2013 7:17 pm
Don't feel bad most of us don't
Ben
Images: 221
Postby Wolffarmer » Wed Feb 27, 2013 9:40 pm
Silvrzuki77 wrote:Lol thanks, frame was pretty easy now i have no idea what im doing lol
Know how you feel. For me the frame was easy also. Then to get to see a TD up close. I had to build one.
:lol: :lol:
Randy
Wolffarmer
Images: 309
