Fire extinguishers?
Fire extinguishers?
Postby les45 » Sat Mar 02, 2013 4:37 pm
I'm sure this has been discussed somewhere before but I couldn't find anything definitive by searching.
Who carries one? Where do you store it? What size? etc..etc..
les45
Images: 605
Re: Fire extinguishers?
Postby TPMcGinty » Sat Mar 02, 2013 4:55 pm
Keep a small ABC in the Jeep.
Tim
TPMcGinty
Images: 146
Postby nevadatear » Sat Mar 02, 2013 5:09 pm
Small abc in rhe suv and one in the galley in the water cabinet. There was a thread awhile back about co detectors and smoke detectors and there was some discussion there.
nevadatear
Images: 171
Postby Gary and Cheri » Sat Mar 02, 2013 5:53 pm
I carry a small extinguisher in the tow and under the hatch next to but far enough away from where I expect to be cooking. I figure engine fire and cooking fire will be the most likely problems.
Gary
Gary and Cheri
Postby pmowers » Sat Mar 02, 2013 8:05 pm
The last discussion that I recall is here http://www.tnttt.com/viewtopic.php?f=38&t=52403&hilit=smoke+detector
I keep several around. You can buy some disposables by Kidde that are rated for either Marine or Automotive. They are capable of handling electrical and flammable liquids, as well as other materials.
I keep several around, as I have said before, I do stupid.
Pat
pmowers
Images: 43
Postby mary and bob » Sat Mar 02, 2013 8:16 pm
When I worked on trucks we changed out fire extinguishers if the pressure gauge was out of the full charge range. I have saved several of the ones with metal valves and had them recharged. They won't recharge the ones with plastic valves. It's standard practice for any commercial business to have all extinguishers inspected on a regular schedule. One of the things they will do when inspecting a small extinguisher is to hit the bottom with a rubber mallet, this keeps the powder from caking up. I keep at least one extinguisher in each vehicle and camper. When on the campsite the extinguisher sets by the right wheel of the trailer.
mary and bob
Postby Ron Dickey » Sat Mar 02, 2013 9:39 pm
viewtopic.php?t=12276
we keep them in the house when we camp we grab one and take it along
173882......173887
Ron Dickey
Images: 787
Postby GerryS » Sat Mar 02, 2013 10:14 pm
Don't go without one. Our toys are too expensive to lose because we don't have a $30 extinguisher...
GerryS
Postby Junkboy999 » Sat Mar 02, 2013 11:41 pm
I always carry one.
Got two in my shop, one in my house and now one in my camper.
Junkboy999
Images: 52
Postby Elizabeth C. » Sun Mar 03, 2013 9:49 am
We have a fire extinguisher in the tow vehicle and one in the galley. Better to have it and never need it then the other way around.
P.S. I also have bear spray (a gag gift from my husband) on the other side of the galley.
Our build in e-book form "The Teardrop Year" available at e-book, book or pdf at book or pdf
Read my Hubbys version here: CrowsWing Teardrop
Elizabeth C.
Images: 356
Postby donaldraver » Sun Mar 03, 2013 5:23 pm
I carry a 2 1/2 pound dry chem abc in the camper a 5 pounder in my truck along with a 2 1/2 gallon pressurized water extinguisher. The PW has been converted to CAF (Compressed Air Foam) you use use half the water add 2 ounces of HE Laundry liquid or dawn dish soap. You drill a 3/32 hole completely through the pickup tube about 3/4 the way up. This allows the air to mix with the water foam solution, providing a sudsy solution that is 5 times more effective then plain water. With a 12 volt air compressor and some soap you can refill most anywhere You still need to protect it from freezing.
donaldraver
Postby skline25 » Mon Mar 04, 2013 9:39 pm
Being in the trade of firefighting, I recommend at minimum of a 2 1/2 pound ABC fire extinguisher in the galley area. A 5 pounder is better as it puts out twice as much fire which is better for white gas appliances. Remember, before heading out this spring on your first trip to pull out your extinguisher and inspect it for corrosion (rust), that the nozzle is clear, if it has a gauge that it reads in the green and turn it upside down and tap the bottom with your hand to loosen up the dry chemical. It becomes compacted over time and with the extinguisher bouncing down the road it accelerates the compaction. Scott
skline25
Images: 5
Postby Corwin C » Mon Mar 04, 2013 11:41 pm
I have a 5 pounder in the TV and planning on another in the galley. My current TTT has a 10 pounder under the sink. I've decided that too much extinguisher is better than not enough.
+1 on taking it out, checking the pressure gauge and turning it over with a couple of sharp thumps. The powder inside should shift around smoothly instead of in a lump. I actually check it as a part of my pre-trip inspection.
Corwin
Image Image Image
-- myself
Corwin C
Images: 78
Postby Irmo Atomics » Tue Mar 05, 2013 6:56 am
I made a holster for mine. It fits into the shelf so that it won't bounce around in transit, it's removable so we can use it in another camper, and it holds the extinguisher at an easy position to grab and shoot if needed. Plus it made a perfect place to stick my clock.
Safety 3rd.jpg (143.08 KiB) Viewed 453 times
Bob
Irmo Atomics
Images: 64
