The Bummer offroad build
Re: The Bummer offroad build
Postby Silvrzuki77 » Fri Mar 01, 2013 11:36 am
Okay I re redid the hatch edge like ben and kc suggested. Opinons?
Also thanks Ben, I didnt catch the 19" radius for the rear! I fixed that also
I plan on doing the inner seal setup like some have suggested for the hatch. I started the laminate flooring also.
If you guys think the hatch looks good I am going to cut it out today and put the walls back up.
Silvrzuki77
Postby Ben » Fri Mar 01, 2013 11:43 am
That looks a lot better! Looks good and keep up the good work! Lol
Going broke quick fixing a bad start!
Ben
Images: 221
Postby KCStudly » Fri Mar 01, 2013 4:01 pm
+1
Yup, that looks better.
If you're happy, we're happy. :thumbsup:
Postby Silvrzuki77 » Fri Mar 01, 2013 7:25 pm
Alrighty!!! Git the floor cut into place for a grand total of 31.26 lol. I glued all the seams, so should be pretty solid.
Got the hatch cut out! Really glad i listened to the advice on it! Looks good!
And over all view
Soo i guess im going to figure where the galley will stop and end then frame the front.
Silvrzuki77
Postby AlgoDan » Fri Mar 01, 2013 7:58 pm
Wow got to say you got a great build going on..I am new here and I am following your build... :beer:
Here now but Camping later.............Dan
Build Journal
http://www.tnttt.com/viewtopic.php?f=50&t=54681
102535 103199 105576
From .................Paper...........................To.......................... Pavement............................
AlgoDan
Images: 238
Postby Ben » Sat Mar 02, 2013 7:16 am
Looking really good chris!!
Ben
Images: 221
Postby Silvrzuki77 » Sun Mar 03, 2013 6:43 pm
Well had sunday off soo got a ton of cleaning and yardwork down and started laying out my galley with tape. I think im happy with it? Lol i plan on using caninet doors on the upper cabinets. The fridge will be mounted on the passenger side just putting it in there for a look. Need to remove the handle and build a low profile setup. This week I am going to pick up some alder wood.
Was thinking about the roof spars any reason i shouldnt use 2x4 cut down to 2x2's for the main roof?
Silvrzuki77
Postby BillZ » Sun Mar 03, 2013 8:39 pm
Love following your build! That floor looks too good to cover up with a mattress.
Was thinking about the roof spars any reason i shouldn't use 2x4 cut down to 2x2's for the main roof?
Sometimes they warp when you do that. It might be better to use pre-seasoned 2x2's that you can pick straight.
You probably know this already but many here use hardwood spars where there is extra stress, like the hatch hinge.
BillZ
Postby Junkboy999 » Mon Mar 04, 2013 3:25 am
Ya on the warping. Building grade 2x4 these days are still sap wet.
If you can find some old hard ones that came out of an old house they would be better.
Another option I seen done here. Some one cut 1” x 4” strips out of bigger Popular boards. Then glued
2 of them together to his spars. They tend to hold each other together and stop most warping. Just watch
out you join them to the side wall. You don’t want to drive them apart with a screw in the glue joint.
This page ( half way down ) show the spars and later how they are installed.
http://www.campingclassics.com/stripper4.html
His homepage and build logs. for later reference. + he sells a nice guide for building.
http://www.campingclassics.com/index.html
Keep us posted.
Junkboy999
Images: 52
Postby Ben » Mon Mar 04, 2013 9:34 am
A lot of people use 1x3 pine for the roof spars and popular wood on the hurricane hinge spar but they double the last spar for more strength you'll also want to glue them together I think most would use epoxy glue or the pl2000 I've never been able to find the pl2000 but I have used the pl200 it's a construction adhesive that's very strong it works the same way as gorilla glue but no need to wet the wood and it don't foam. I used the 3x premium strength. 1 thing I found is to use a notch trowel to spread it other wise if you don't its hard to get tight joints. It's thick as all get out.
Ben
Images: 221
Postby Silvrzuki77 » Mon Mar 04, 2013 11:38 am
I was planning on using some oak for the hatch spar. I tried taking 1x4 and ripping them in half and then gluing them together. The wood is soo crooked its not from my cut but just not being perectly straight from the getgo. I need to take a picture of it.
Silvrzuki77
Postby Ben » Mon Mar 04, 2013 11:46 am
It's always wiser to get boards wider and rip to desired width but you have to start with good straight lumber unless you have a jointer and a planner.
Ben
Images: 221
Postby Silvrzuki77 » Mon Mar 04, 2013 11:50 am
I have neither lol
Silvrzuki77
Postby Ben » Mon Mar 04, 2013 11:54 am
I lucked out and my neighbor gave me a pile of white oak ruff cut boards. I have a planner if you don't mind the drive to Ohio lol. But I was able to cut them to size and plane to desired size.
Ben
Images: 221
Postby Silvrzuki77 » Fri Mar 08, 2013 5:33 pm
Well got rained out today soni couldnt get the galley wood. Been talking a to a few people everyone suggested i make a second door. Soo i did. I pee all the time so what the heck lol. Started planning with the framing around the door for the inside to seal and started at 1/4" not enough, specially since most door seals are 3/8th lol soo ill try again tomorrow. Hopefully I will be able to pick up my wood also.
Silvrzuki77
Users browsing this forum: Google [Bot] and 1 guest
