Simple Maryland 5 wide build
Re: Simple Maryland 5 wide build
Postby JTROBB » Fri Feb 22, 2013 12:50 pm
I have about $300 dollars in materials for the fiberglass. I bought the Fiberglass cloth on sale as it was the last 20 yards on a bolt, I think it was something like $2.85 a yard. I am also using a store branded epoxy which is much cheaper, like $75 a gallon. I have had to buy a second Gallon as it looks like the first gallon is not going to finish the project. That all said , I'm not sure it will be cheaper as I also have to purchase paint to provide the UV protection needed. I think it may be more labor intensive too. The amount of time I have spent on the roof alone I could have skinned and trimmed the whole tear and I'm not finished with the roof. My reason for Fiberglassing vs Aluminum sheet is I want to make sure there is no water intrusion. Plywood boats use the same process to make them water tight so I figure this should work great a I do not plan to submerge my tear. I have no plans for any trim as this would require penetrating the fiberglass.
Jason
JTROBB
Images: 132
Postby JTROBB » Mon Feb 25, 2013 6:53 pm
Lots of sanding. I have the rear sanded smooth and a coat of primer to use as a guide coat. Probably have a couple of more fill coats before it is all wave free.
Jason
102556102557
JTROBB
Images: 132
Postby RandyG » Tue Feb 26, 2013 6:47 pm
Lookin' good! :applause:
What's your topcoat going to be?
Randy
RandyG
Images: 115
Postby JTROBB » Wed Feb 27, 2013 6:45 pm
Block sanded the primer today and had 4.5 roof supports that showed a bit of wave to them so another coat of filler in those spots. I plan to top coat in a automotive urethane but still a lot of sanding to do before that.
Jason
JTROBB
Images: 132
Postby JTROBB » Fri Mar 01, 2013 7:35 pm
Last coat of fill for the Top. The 2K primer says to use the catalyst within 14 days of opening so I'll wait to spray when the sides are done. Looks like Sunday I will have some friends over to help flip it on its side to fiberglass the first side and enclose and fiberglass the bottom.
Jason
102725102726
JTROBB
Images: 132
Postby JTROBB » Sun Mar 03, 2013 5:39 pm
We got it flipped and it was not that big of a deal with 3 of us. Time to start on the side and insulate and enclose the bottom.
Jason
102837102838102839102840102841
JTROBB
Images: 132
Postby JTROBB » Tue Mar 05, 2013 6:58 pm
Smoothed out some of the rough spots on the side. Insulated the floor and started to enclose the bottom of the floor.
Jason
102971102970102972102973
JTROBB
Images: 132
Postby JTROBB » Wed Mar 06, 2013 2:59 pm
Took a snow day even though I haven't seen snow since 4:00am. I got the bottom closed up and the fiberglass on the side. Doesn't sound like much but took better part of the day.
Jason
102995102996102997
JTROBB
Images: 132
Postby KCStudly » Thu Mar 07, 2013 12:33 am
Progress is progress. One step at a time.
Looking good. :thumbsup:
Postby Shadow Catcher » Thu Mar 07, 2013 6:17 am
It is amazing how much time a seemingly simple task can take. Looking good!
Postby AlgoDan » Thu Mar 07, 2013 6:56 am
Looking good, be done in time for the camping season for sure.
Here now but Camping later.............Dan
Build Journal
http://www.tnttt.com/viewtopic.php?f=50&t=54681
102535 103199 105576
From .................Paper...........................To.......................... Pavement............................
AlgoDan
Images: 238
Postby JTROBB » Thu Mar 07, 2013 7:57 pm
I managed to get 2 weave fill coats on the side of the teardrop today. Hopefully only 1 or 2 more coats and a little sanding in between.
Jason
103005103006103007103008
JTROBB
Images: 132
Postby KCStudly » Thu Mar 07, 2013 10:51 pm
That's going to be one slick trailer, like a Faberge egg. :thumbsup:
Postby JTROBB » Fri Mar 08, 2013 8:53 pm
Put one more coat of epoxy on the first side sanded and everything look good with the exception of a few touch ups needed. Completed the touch ups and flipped the tear to start on the other side. Got the second side prepped and glass laying on it to start epoxying in the morning.
103074103075103078103076103077
JTROBB
Images: 132
Postby JTROBB » Sat Mar 09, 2013 7:50 pm
I fiber glassed the second side today and got 3 fill coats on. Hopefully sand tomorrow and spot fill any problem areas.
Jason
103097103098103099103100
JTROBB
Images: 132
