CarlLaFong wrote:$1500 or less is pretty optimistic unless you are the worlds best scrounger or you are planning on something that is ultra minimalistic with no power or cooking facilities. .....but I think you need to double, if not triple, your estimate. Other experienced builders will chime in, I'm sure.
KCStudly wrote:There's a saying,
You can have it: Good, Fast, Cheap.
Pick two.
WhitneyK wrote:CarlLaFong wrote:$1500 or less is pretty optimistic unless you are the worlds best scrounger or you are planning on something that is ultra minimalistic with no power or cooking facilities. .....but I think you need to double, if not triple, your estimate. Other experienced builders will chime in, I'm sure.
Don't listen to him Irving!![]()
I built mine for $1400! (I know, some will say it looks it too!)
Dig around for the bargains, use what you've got, and good luck!![]()
It depends on how fast you want to build it. Good (& cheap) things come to those who wait.
Irving wrote:Just looking at some of the pics of your rig. Looks good to me! Did the aluminum take up a lot of your budget?
mezmo wrote:Don't use Mobile Home Aluminum roof coat as an exterior
finish ! It is not meant to be a surface "finish". It is applied
as a thicker coating and will continously rub off on whatever
touches/abrades it. The aluminum portion of it generally is at
the topmost surface of the coating ["floating there"] and if you
wear that away the underpart of the coating is then exposed
and that is probably a tar-based coating, if it is one of the
cheaper aluminum roof coatings.
